iLogic rule to change view rep members seems to make interface unstable.
nbonnett-murphy
nbonnett-murphy
I have this script which takes a selection set, asks the user to add or remove, then unlocks the current view rep, adds/removes the selected items, then relocks the view rep.
For some reason it seems to destabilize the interface. Specifically, the locked/unlocked icons on the view reps don't update properly until you deselect and reselect the active view rep. Also, I went to another part context and dragging the pointer around in the tree didn't update it's apparent position, but would still suppress/unsuppress features as if it was being moved. It also causes a problem where the undo buffer isn't accessible. Even if I make changes, it stays greyed out, and ctrl-Z doesn't reverse changes. I'm guessing that one might be caused by having "exit sub"s happen without closing the transaction so it get's stuck open if I happen to error out during testing.
Can someone help me figure out why this would cause interface problems and what I can do to prevent it? I know there are interface update commands, but I'm not sure where to start with that.
Sub Main
	Dim oTransMgr As TransactionManager = ThisApplication.TransactionManager
	Dim oTrans As Transaction = oTransMgr.StartTransaction(ThisApplication.ActiveDocument, "View Rep Script")
	Dim oDoc As Inventor.Document = ThisApplication.ActiveEditDocument
	Dim sSet = oDoc.SelectSet
	Dim selectedStuff As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
	Dim allViewReps = oDoc.ComponentDefinition.representationsManager.designviewrepresentations
	Dim oStartingRep As DesignViewRepresentation = oDoc.ComponentDefinition.representationsManager.ActiveDesignViewRepresentation
	Dim oStartingRepName As String = oStartingRep.Name.ToString
	If sSet.Count = 0 Then
		ThisApplication.StatusBarText = "Empty selection set. Exiting script."
		Exit Sub
	End If
	For Each thing In sSet
		selectedStuff.Add(thing)
	Next
	Logger.Info("Set active rep: {0}", oStartingRep.Name)
	Logger.Info("{0} items selected", selectedStuff.Count)
	userResponse = MsgBox("Do you want these IN the view rep?", vbYesNoCancel,"Add or remove?")
	If userResponse = vbYes
		addOrRemove = True
		oAction = "Including "
	ElseIf userResponse = vbNo
		addOrRemove = False
		oAction = "Excluding "
		Else
			ThisApplication.StatusBarText = "View rep change cancelled."
			Exit Sub
	End If
	Try
		allViewReps.item(oStartingRepName).locked = False
		allViewReps.item(oStartingRepName).SetVisibilityOfOccurrences(selectedStuff, addOrRemove)
		allViewReps.item(oStartingRepName).locked = True
		ThisApplication.StatusBarText = "View rep " & oStartingRepName & ": " & oAction & selectedStuff.Count.ToString & " item(s)."
	Catch
		ThisApplication.StatusBarText = "Failed to change view rep " & oStartingRepName
	End Try
	oTrans.End
End Sub
nbonnett-murphy
After a little bit more testing, I believe that the undo problem was related to the transaction getting stuck open if the script errors out. I added oTrans.End before every "exit sub" and that seems to have helped. Not yet clear if it also fixes the interface problems.
Curtis_Waguespack
@nbonnett-murphy, I don't know that I have a solution for you, but as soon as I saw the Transaction, I was going to reply that it was going to be the source of this issue ( based on my own experience with transactions). So you're on the right track.
You might want to use abort before the Exit Subs and in the Catch of your Try/Catch
oTrans.abort
nbonnett-murphy
Yep, looks like that pretty much did it thanks. I'll need to go through my other scripts where I use the transaction manager to make sure there aren't any cases where it gets left open like this one.
