Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Open Part directly from Assembley in new window
9 REPLIES 9
Message 1 of 10
damjan_baraga
336 Views, 9 Replies
 I'd like to make a rule to open Part directly from the Assembly. It must be opened in a new window to make rules continuing to the next step (for ex. i'd like to make part from Standard part to Sheet metal)
I made
Dim oOcc As ComponentOccurrence
oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "'Select an assembly occurrence.")
If oOcc Is Nothing Then
	MsgBox("You did not select anything. Exiting.", , "")
	Exit Sub
Else
	MsgBox("You selected an assembly occurrrence named " & oOcc.Name & ".ipt")
Try
	ThisDoc.Launch(Component.InventorComponent(oOcc).Definition.Document.FullFileName)
Catch
	MsgBox("File has not been saved or other issue opening file occurred")
	Exit Sub
End Try
 I made start, but then I get error in line
9 REPLIES 9
Message 2 of 10
Hi @damjan_baraga ,
This should work for you:
	Exit Sub
Else
	Dim oDoc As Document = oOcc.Definition.Document
	ThisApplication.Documents.Open(oDoc.FullFileName)
I hope this helps.
Curtis
Message 3 of 10
Thanks. Working.
Message 4 of 10
After I put whole rule I get error in same line.
The whole rule is:
	Exit Sub
Else
    Dim PartDoc As PartDocument
     PartDoc = ThisApplication.ActiveDocument
        ' Convert it to a sheet metal type.
        PartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
        Dim smDef As SheetMetalComponentDefinition
         smDef = PartDoc.ComponentDefinition
        ' Unfold the part.  This will activate the flat pattern environment.
        smDef.Unfold
        ' Exit the flat pattern environment.
        smDef.FlatPattern.ExitEdit
'On Error Resume Next
'Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
'Dim CadlineSheetMetal As SheetMetalComponentDefinition
CadlineSheetMetal = oDoc.ComponentDefinition
'CadlineSheetMetal.FlatPattern.Delete
CadlineSheetMetal.Unfold
Cadline = ThisApplication.ActiveDocument.ComponentDefinition
X= 10*( Cadline.RangeBox.MaxPoint.X - Cadline.RangeBox.MinPoint.X)
Y= 10*( Cadline.RangeBox.MaxPoint.Y - Cadline.RangeBox.MinPoint.Y)
Z= 10*( Cadline.RangeBox.MaxPoint.Z - Cadline.RangeBox.MinPoint.Z)
Parameter.Quiet = True
THICKNESS = MinOfMany(X, Y, Z)
ThisDoc.Document.ComponentDefinition.UseSheetMetalStyleThickness = False
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
oSheetMetalCompDef = oPartDoc.ComponentDefinition
Dim oThicknessParam As Parameter
oThicknessParam = oSheetMetalCompDef.Thickness
oThicknessParam.Value = THICKNESS/10
'oPartDoc.Update
LENGTH = MaxOfMany(X, Y, Z)
If X < LENGTH Then
WIDTH = X
If Y < LENGTH Then
WIDTH = Y
If Z < LENGTH Then
WIDTH = Y
iProperties.Value("Custom", "LENGTH") = Round(LENGTH, 1)
iProperties.Value("Custom", "WIDTH") = Round(WIDTH, 1)
iProperties.Value("Custom", "THICKNESS") = Round(THICKNESS, 1)
iProperties.Value("Project", "Authority") = iProperties.Value("Custom", "THICKNESS")
iProperties.Value("Summary", "Comments") = "laser"
RuleParametersOutput()
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
'set iproperty to use ISO view on save
oDoc.SetThumbnailSaveOption _
(ThumbnailSaveOptionEnum.kActiveComponentIsoViewOnSave)
oDoc = ThisApplication.ActiveEditDocument
'get current colorcheme name
oColorScheme = ThisApplication.ActiveColorScheme.Name
'Change to Presentation
ThisApplication.ColorSchemes.Item("Presentation").Activate
ThisApplication.ColorSchemes.BackgroundType = 52737
ThisDoc.Save
'Change back to original scheme
ThisApplication.ColorSchemes.Item(oColorScheme).Activate
Call PartDoc.Close(True)
 The rule works without your add. This I get:
Message 5 of 10
Hi @damjan_baraga
Here is an updated version of your code.
I hope this helps.
Curtis
	Exit Sub
oDoc = ThisApplication.Documents.Open(oOcc.Definition.Document.FullFileName)
oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
smDef = oDoc.ComponentDefinition
smDef.Unfold
X = 10 * (Cadline.RangeBox.MaxPoint.X - Cadline.RangeBox.MinPoint.X)
Y = 10 * (Cadline.RangeBox.MaxPoint.Y - Cadline.RangeBox.MinPoint.Y)
Z = 10 * (Cadline.RangeBox.MaxPoint.Z - Cadline.RangeBox.MinPoint.Z)
Try
Catch
	MsgBox("could not set 'UseSheetMetalStyleThickness'", , "iLogic")
	Exit Sub
End Try
oSheetMetalCompDef = oDoc.ComponentDefinition
oThicknessParam.Value = THICKNESS / 10
'oDoc.Update
If X < LENGTH Then
	WIDTH = X
If Y < LENGTH Then
	WIDTH = Y
If Z < LENGTH Then
	WIDTH = Y
oDoc.Save
Call oDoc.Close(True)
Message 6 of 10
Its working till here:
Try
Catch
	MsgBox("Could not set 'UseSheetMetalStyleThickness'", , "iLogic")
	Exit Sub
End Try
Then I get:
Message 7 of 10
My apologies, I put that error catch in, but I misinterpreted the error. It should be as shown below:
Try
	oDoc.ComponentDefinition.UseSheetMetalStyleThickness = False
Catch
	Exit Sub
End Try
Message 8 of 10
There must some errors, too, because I don't get data in iProperties.
Message 9 of 10
iProperties.Value(oOcc.Name, "Custom", "LENGTH") = Round(LENGTH, 2)
iProperties.Value(oOcc.Name, "Custom", "WIDTH") = Round(WIDTH, 2)
iProperties.Value(oOcc.Name, "Custom", "THICKNESS") = Round(THICKNESS, 2)
iProperties.Value(oOcc.Name, "Project", "Authority") = iProperties.Value("Custom", "THICKNESS")
iProperties.Value(oOcc.Name, "Summary", "Comments") = "laser"
Message 10 of 10
Now working. Many Thanks.
