[iLogic] 'rebuild all' error
matroosoft
Message 1 of 23
matroosoft
Am trying to perform a 'rebuild all' on the active (assembly) document using iLogic, using:
ThisApplication.ActiveDocument.Rebuild()
It returns "incorrect parameter. Exception from HRESULT: 0x80070057 (E_INVALIDARG))". Also tried to use 'rebuild2', but that gave the same error. What am I doing wrong?
Replies (22)
Message 2 of 23
bradeneuropeArthur
What version of inventor are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 23
matroosoft
Inventor 2015
Message 4 of 23
bradeneuropeArthur
what happens when you manually rebuild all?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 23
HermJan.Otterman
what happens if you try this:
 ThisDoc.Document.rebuild
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 6 of 23
matroosoft
If I manually click 'rebuild all' then the model rebuilds without any error.
Message 7 of 23
matroosoft
                [code]
It returns the same error if I use that.
Message 8 of 23
bradeneuropeArthur
could you please provide the complete coding?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 23
matroosoft
This is the complete coding:
SyntaxEditor Code Snippet
Sub Main()
    Dim assDoc As AssemblyDocument = ThisDoc.Document
    'If assDoc.ComponentDefinition.Occurrences(2).Definition.Document.LevelOfDetailName = "Master" Then
    '    MsgBox("This logic only works if subassembly 2 is not set to Master Level of Detail")
    '    Exit Sub
    'End If
    If assDoc.ComponentDefinition.Occurrences(1).Suppressed=False Then
        Dim subAssDoc1 As AssemblyDocument = assDoc.ComponentDefinition.Occurrences(1).Definition.Document
        Dim noOfComponentsInSubAssembly1 As Integer = subAssDoc1.ComponentDefinition.Occurrences.Count
        For i = 1 To noOfComponentsInSubAssembly1
            For j = 2 To 25
                If Not assDoc.ComponentDefinition.Occurrences(j).Suppressed Then
                    If subAssDoc1.ComponentDefinition.Occurrences(i).Suppressed Then
                        assDoc.ComponentDefinition.Occurrences(j).Definition.Occurrences(i).Suppress()
                    Else
                        assDoc.ComponentDefinition.Occurrences(j).Definition.Occurrences(i).Unsuppress()
            Next
        Next
    InventorVb.DocumentUpdate()
    If assDoc.ComponentDefinition.Occurrences(26).Suppressed=False Then
        Dim subAssDoc26 As AssemblyDocument = assDoc.ComponentDefinition.Occurrences(26).Definition.Document
        Dim noOfComponentsInSubAssembly26 As Integer = subAssDoc26.ComponentDefinition.Occurrences.Count
        For i = 1 To noOfComponentsInSubAssembly26
            For j = 27 To 50
                    If subAssDoc26.ComponentDefinition.Occurrences(i).Suppressed Then
                    Else
            Next
        Next
    If assDoc.ComponentDefinition.Occurrences(51).Suppressed=False Then
        Dim subAssDoc51 As AssemblyDocument = assDoc.ComponentDefinition.Occurrences(51).Definition.Document
        Dim noOfComponentsInSubAssembly51 As Integer = subAssDoc51.ComponentDefinition.Occurrences.Count
        For i = 1 To noOfComponentsInSubAssembly51
            For j = 52 To 75
                    If subAssDoc51.ComponentDefinition.Occurrences(i).Suppressed Then
                    Else
            Next
        Next
    If assDoc.ComponentDefinition.Occurrences(76).Suppressed=False Then
        Dim subAssDoc76 As AssemblyDocument = assDoc.ComponentDefinition.Occurrences(76).Definition.Document
        Dim noOfComponentsInSubAssembly76 As Integer = subAssDoc76.ComponentDefinition.Occurrences.Count
        For i = 1 To noOfComponentsInSubAssembly76
            For j = 77 To 100
                    If subAssDoc76.ComponentDefinition.Occurrences(i).Suppressed Then
                    Else
            Next
        Next
    If assDoc.ComponentDefinition.Occurrences(101).Suppressed=False Then
        Dim subAssDoc101 As AssemblyDocument = assDoc.ComponentDefinition.Occurrences(101).Definition.Document
        Dim noOfComponentsInSubAssembly101 As Integer = subAssDoc101.ComponentDefinition.Occurrences.Count
        For i = 1 To noOfComponentsInSubAssembly101
            For j = 102 To 125
                    If subAssDoc101.ComponentDefinition.Occurrences(i).Suppressed Then
                    Else
            Next
        Next
    ThisApplication.ActiveDocument.Save2
    iLogicVb.UpdateWhenDone = True
End Sub
Message 10 of 23
bradeneuropeArthur
try this:
'And then:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 23
matroosoft
Already tried that, but that didn't make any difference unfortunately.
Message 12 of 23
bradeneuropeArthur
Your assembly is only containing subassemblies?????????
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 23
bradeneuropeArthur
Change to this:
assDoc.Update
assDoc.Save
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 23
matroosoft
Yes and one of them is patterned using a component pattern.
                Change to this:
                [code]
The 'update' part doesn't perform a rebuild on the model or am I wrong?
Message 15 of 23
bradeneuropeArthur
For me it worked.
I have not the same assembly as you have, but this works at least.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 23
matroosoft
For me it doesn't work. Have tried using a save command, which rebuilds the model as well, but saving the assembly is undesirable. I thought if there is a method 'rebuild' or 'rebuild2' at least one of them should work. Anyone else who can point out why it isn't working?
Message 17 of 23
bradeneuropeArthur
Can you please check the following:
put this piece of code in your assembly file in I logic:
then put this piece of code in your assembly file in VBA:
then please provide me the information if it works in both environments or not
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 23
matroosoft
I've just tested that in VBA, but didn't know how to write the surrounding code. The single line didn't work, it gave me a compile error.
I've found something interesting though: I tested the line in a iLogic rule when I opened the concerning assembly without changing anything, and then it worked. Then I tried the same rule after running a configurator plugin (which we use for this assembly). This configurator changes a few parameters of my assembly to default values if I run it. I ran the configurator, then the same iLogic rule didn't work anymore (it gave the aforementioned error).
Is there something known which would prevent running the 'rebuild' method?
Edit: found that it has something to do with the complete iLogic rule that I've posted earlier. After running that iLogic rule the rebuild method gives an error. The complete iLogic rule is also triggered by the configurator plugin we use so that's why the rebuild method wouldn't run after running the configurator either.
Edit 2: Found the problem:
This combination doesn't work. Save2 method neither. Don't ask me why, but removing the line which saves the document, solves the problem. In this case that line isn't necessary so as far as I am concerned it is solved. But this behaviour seem to me as unintended? Maybe a little bug?
Message 19 of 23
bradeneuropeArthur
For VBA place this in a new module:
Public Sub reb()
Call ThisApplication.ActiveDocument.Rebuild
End Sub
please let me know the outcome...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 23
matroosoft
Thanks, tried it but gave the same results as in iLogic code. In a fresh started assembly it does work, but after using the iLogic code to save the document, the same VBA code doesn't run (it gave a invalid argument error).
Edit: I've also tested if I could manually click 'rebuild all' after using the iLogic save method, but then Inventor freezes (and doesn't come back to life).
Another edit: After the configurator plugin has suppressed/unsuppressed a few items and changed some values the rebuild method again doesn't work. Even with the line with the save method removed. Manually clicking 'rebuild all' does it's job, though it first asks if I want to save the document.
Edit 3: weird stuff happening. After manually rebuilding, the iLogic rule runs again without any error. Until I use the save method or the configurator changes a few things. Then the iLogic rule will give an error again.
