- Mute
- Permalink
- Report
Could you please help me out with additional code to pick up all occurrences from BOM to be linked to SQL database.
At the moment only last component is imported to SQL table.
Thanks.
AddReference "System.Data"
AddReference "System.Core"
AddReference "System.Xml"
Imports System.Data.OleDb
Imports System.Data
Imports System.Xml
Sub main
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
'----------change BOM normal to phantom for parts with description NOT ON BOM
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim CompOcc As ComponentOccurrence
For Each CompOcc In oAsmCompDef.Occurrences
If CompOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value = "NOT ON BOM" Then
CompOcc.Definition.BOMStructure = 51971 'Phantom
Else
End If
Next
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
'You can change the output path by editing oPATH below
oPATH = PROJECT_PATH & JOB_NO & " - " & CLIENT & " - " & SITE & "\" 'If you change this, remember to keep a \ at the end
'STRUCTURED BoM ===========================================================================
' the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
Dim oStructuredBOMView As BOMView
oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
oStructuredBOMView.Export(oPATH + ThisDoc.FileName(False) + ".xls", kMicrosoftExcelFormat)
'PARTS ONLY BoM ===========================================================================
'' Make sure that the parts only view is enabled.
'oBOM.PartsOnlyViewEnabled = True
'Dim oPartsOnlyBOMView As BOMView
'oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
'' Export the BOM view to an Excel file
'oPartsOnlyBOMView.Export (oPATH + "BOM-PartsOnly.xls", kMicrosoftExcelFormat)
'BOM to SQL
Dim row As Integer = 5
row = 5
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
Dim PartNumber, Qty, StockNumber, Description As String
'Dim bRow As bomRow
bRows = oBOMView.BOMRows
For Each bRow In bRows
Dim rDoc As Document
rDoc = bRow.ComponentDefinitions.Item(1).Document
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
StockNumber = bRow.ItemNumber
Qty = bRow.ItemQuantity
Description = docPropertySet.Item("Description").Value
PartNumber = docPropertySet.Item("Part Number").Value
row = row + 1
Next
Dim sConn As String = String.Empty
sConn="Provider=SQLOLEDB;Data Source=XXXXX;Initial Catalog=XXXXX;User ID=XXXXXXX;Password=XXXXXX;Connect Timeout=30;Encrypt=True;TrustServerCertificate=False;ApplicationIntent=ReadWrite;MultiSubnetFailover=False"
'Enter Tablename and values to insert
'If there are less values than columns in your table, you need to specify wich value corresponds to which column
Dim sql As String = String.Empty
sql = "INSERT INTO InventorBOM1 VALUES ('"& JOB_NO &"','"& PROJECT_ID &"','"& PartNumber &"','"& Qty &"','"& Description &"','"& StockNumber &"')"
If ExtSql(sConn, sql) Then
MsgBox("Command executed", MsgBoxStyle.Information, "iLogic")
End If
End Sub
Function ExtSql(ByVal sConn As String, ByVal sql As String) As Boolean
Dim cnn As OleDbConnection
Dim cmd As OleDbCommand
cnn = New OleDbConnection(sConn)
Try
cnn.Open()
cmd = New OleDbCommand
cmd.Connection = cnn
cmd.CommandType = System.Data.CommandType.Text
cmd.CommandText = sql
cmd.ExecuteNonQuery()
cnn.Close()
cmd.Dispose()
Catch ex As Exception
cnn.Close()
Return False
End Try
Return True
End Function
