iLogic linked to SQL but only last item is imported to database
justinparfitt
justinparfitt
Could you please help me out with additional code to pick up all occurrences from BOM to be linked to SQL database.
At the moment only last component is imported to SQL table.
Thanks.
AddReference "System.Data"
AddReference "System.Core"
AddReference "System.Xml"
Imports System.Data.OleDb
Imports System.Data
Imports System.Xml
Sub main
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
'----------change BOM normal to phantom for parts with description NOT ON BOM
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim CompOcc As ComponentOccurrence
For Each CompOcc In oAsmCompDef.Occurrences
If CompOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value = "NOT ON BOM" Then
CompOcc.Definition.BOMStructure = 51971 'Phantom
Else
End If
Next
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
'You can change the output path by editing oPATH below
oPATH = PROJECT_PATH & JOB_NO & " - " & CLIENT & " - " & SITE & "\" 'If you change this, remember to keep a \ at the end
'STRUCTURED BoM ===========================================================================
' the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
Dim oStructuredBOMView As BOMView
oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
oStructuredBOMView.Export(oPATH + ThisDoc.FileName(False) + ".xls", kMicrosoftExcelFormat)
'PARTS ONLY BoM ===========================================================================
'' Make sure that the parts only view is enabled.
'oBOM.PartsOnlyViewEnabled = True
'Dim oPartsOnlyBOMView As BOMView
'oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
'' Export the BOM view to an Excel file
'oPartsOnlyBOMView.Export (oPATH + "BOM-PartsOnly.xls", kMicrosoftExcelFormat)
'BOM to SQL
Dim row As Integer = 5
row = 5
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
Dim PartNumber, Qty, StockNumber, Description As String
'Dim bRow As bomRow
bRows = oBOMView.BOMRows
For Each bRow In bRows
Dim rDoc As Document
rDoc = bRow.ComponentDefinitions.Item(1).Document
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
StockNumber = bRow.ItemNumber
Qty = bRow.ItemQuantity
Description = docPropertySet.Item("Description").Value
PartNumber = docPropertySet.Item("Part Number").Value
row = row + 1
Next
Dim sConn As String = String.Empty
sConn="Provider=SQLOLEDB;Data Source=XXXXX;Initial Catalog=XXXXX;User ID=XXXXXXX;Password=XXXXXX;Connect Timeout=30;Encrypt=True;TrustServerCertificate=False;ApplicationIntent=ReadWrite;MultiSubnetFailover=False"
'Enter Tablename and values to insert
'If there are less values than columns in your table, you need to specify wich value corresponds to which column
Dim sql As String = String.Empty
sql = "INSERT INTO InventorBOM1 VALUES ('"& JOB_NO &"','"& PROJECT_ID &"','"& PartNumber &"','"& Qty &"','"& Description &"','"& StockNumber &"')"
If ExtSql(sConn, sql) Then
MsgBox("Command executed", MsgBoxStyle.Information, "iLogic")
End If
End Sub
Function ExtSql(ByVal sConn As String, ByVal sql As String) As Boolean
Dim cnn As OleDbConnection
Dim cmd As OleDbCommand
cnn = New OleDbConnection(sConn)
Try
cnn.Open()
cmd = New OleDbCommand
cmd.Connection = cnn
cmd.CommandType = System.Data.CommandType.Text
cmd.CommandText = sql
cmd.ExecuteNonQuery()
cnn.Close()
cmd.Dispose()
Catch ex As Exception
cnn.Close()
Return False
End Try
Return True
End Function
A.Acheson
The for loop retrieving the iproperty values does not contain the function call for the SQL database. Move all items relating to the function "ExtSql(sConn, sql)"
    ' ..... iProperties
    ExtSql(sConn, sql)
Next
Regards
Alan
justinparfitt
Thank you for the pointing me in the correct direction.
I have moved the ExtSql(sConn, sql) to the loop as code below, and it is importing correct qty of components(on BOM showed 3 items, and sql is showing 3 items (job no and door ref), but there is no description, qty, stocknumber and partnumber. So, it looks like it is not picking up the string.  Any ideas on this one? Thanks...
'BOM to SQL
	sConn="Provider=SQLOLEDB;Data Source=XXX;Initial Catalog=XXX;User ID=XXX;Password=XXX;Connect Timeout=30;Encrypt=True;TrustServerCertificate=False;ApplicationIntent=ReadWrite;MultiSubnetFailover=False"
	sql = "INSERT INTO InventorBOM1 (JOB_NO,PROJECT_ID,ITEM,Qty,Description,StockNumber) VALUES ('"& JOB_NO &"','"& PROJECT_ID &"','"& PartNumber &"','"& Qty &"','"& Description &"','"& StockNumber &"')"
row = 5
Dim bRow As BOMRow
'For each row in the Structured BOM, do the following
'Set a reference to the primary ComponentDefinition of the row
row = row + 1
ExtSql(sConn, sql)
Next
A.Acheson
It might be good practice to place "Option Explicit On" line in the header section of the code. This will help identify more issues. The sql string variable is being set before you have any string iproperty placed into it.  That should be located after the iproperty strings are created and before it is passed into the sql function.
Regards
Alan
justinparfitt
Thank you very much for your help. Below is the final code.
Sub main
Else
End If
Next
Dim oBOM As BOM
'BOM to SQL
row = 5
Dim bRow As BOMRow
	row = row + 1
	sConn="Provider=SQLOLEDB;Data Source=xxxxx;Initial Catalog=xxxx;User ID=xxxxx;Password=xxxx;Connect Timeout=30;Encrypt=True;TrustServerCertificate=False;ApplicationIntent=ReadWrite;MultiSubnetFailover=False"
	ExtSql(sConn, sql)
	Next
End Sub
    Try
        cnn.Open()
        cnn.Close()
        cmd.Dispose()
        cnn.Close()
        Return False
    End Try
    Return True
End Function
