Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic external rule for parts and assembly
1 REPLY 1
gert-leonvanlier
321 Views, 1 Reply
I am having issues with one of my external rules and I can't figure out why. The rule is working perfectly in a part document. This part becomes an asset for the Factory Design Suite. When I place this asset then into my layout I get the following error:
I think it has something to do with the ComponentDefinition difference between a part and assembly, but I don't know how to solve this.
The rule is external because every asset in my library is using the same rule.
This is the code:
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim InvApp As Application = ThisApplication
Dim oAnnotation3D As ModelAnnotation
i = 1
For Each ModelAnnotation In oCompDef.ModelAnnotations
	oAnnotation3D = oCompDef.ModelAnnotations.Item(i)
	If SharedVariable("State") = "Dimensions" And InStr(oAnnotation3D.Name, "Dimension") Then
		If oAnnotation3D.HealthStatus.value__ <> 11778 Then
			oAnnotation3D.Visible = False
		Else oAnnotation3D.Visible = True
		End If
	Else If InStr(oAnnotation3D.Name, "Dimension") Then
	End If
i = i + 1
Next
A part that uses the rule and is working fine on its own is also attached.
1 REPLY 1
I found a solution:
Sub Main()
	Dim topDoc As Document = ThisDoc.Document
	ProcessDoc(topDoc)
	For Each doc As Document In topDoc.AllReferencedDocuments
		ProcessDoc(doc)
	Next
End Sub
Sub ProcessDoc(doc As Document)
	If (doc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
		Dim partDoc As PartDocument = doc
		ProcessPart(partDoc)
	End If
End Sub
Sub ProcessPart(partDoc As PartDocument)
	Dim oCompDef As PartComponentDefinition = partDoc.ComponentDefinition
	i = 1
			End If
		End If
	i = i + 1
	Next
End Sub
Technology Administrators
