Hello Everyone,
I am running into an issue with some code and I am hoping someone here can help me. I am trying to create an iLogic rule (see bottom of this post) that will center and arrange dimensions on all sheets of a drawing. While rummaging through this forum, I have found some code that does the trick. (It's a bit of a Frankenstein's monster of two different code I found.) Once I confirmed that this works in the current drawing, I copy and paste the rule in another drawing and try to run it. Sometimes, the code will run fine in the new document. most of the time, I get the following error.
Error Message Tab
Error in rule: Rule2, in document: DSFAB-XXX-001.idw Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
More Info Tab
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL)) at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData) at Inventor.DrawingDimensions.Arrange(ObjectCollection DrawingDimensions, Object ContourEntity) at LmiRuleScript.Main() at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem) at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
I'm sure there is something wrong with my rule. It's a merger of a "center dims" and "arrange dims" rule. If any of you have a few moments to look through this and show me where I went wrong, I would be very grateful.
iLogic Code
Dim doc As Inventor.DrawingDocument = ThisDoc.Document For Each sheet As Sheet In doc.Sheets 'sheet.Activate Dim dimensions As Inventor.ObjectCollection = ThisServer.TransientObjects.CreateObjectCollection Dim drawDim As Inventor.DrawingDimension For Each drawDim In sheet.DrawingDimensions If Not TypeOf drawDim Is Inventor.OrdinateDimensionSet _ And Not TypeOf drawDim Is Inventor.BaselineDimensionSet _ And Not TypeOf drawDim Is Inventor.ChainDimensionSet Then dimensions.Add(drawDim) End If Next sheet.DrawingDimensions.Arrange(dimensions) Next 'Set a reference To the active drawing document Dim odoc As Document odoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet Dim oSheet As Sheet For Each oSheet In oDoc.Sheets Dim oDrawingDim As DrawingDimension ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. For Each oDrawingDim In oSheet.DrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Or _ TypeOf oDrawingDim Is AngularGeneralDimension Then oDrawingDim.CenterText End If Next Next
I am running Inventor 2016
This is the code I am currently running to arrange all dimensions. Hope it helps in some small way.
SyntaxEditor Code Snippet
'define application Dim oApp As Application oApp = ThisApplication 'define active doc Dim oDoc As DrawingDocument oDoc = oApp.ActiveDocument 'get dims Dim oDims As DrawingDimensions oDims = oDoc.ActiveSheet.DrawingDimensions 'create dim collection Dim oDimCol As ObjectCollection oDimCol = oApp.TransientObjects.CreateObjectCollection 'step through all dims one at a time Dim oDim As DrawingDimension For Each oDim In oDims If TypeOf oDim Is LinearGeneralDimension _ Or TypeOf oDim Is AngularGeneralDimension Then oDim.CenterText 'center the dim oDimCol.Add(oDim) 'add the dim to collection End If Next 'arrange the collection of dims oDims.Arrange(oDimCol)
Thank you. Your rule is much cleaner and easier to understand than mine is. Any idea if it is possible to make this work on all sheets in a drawing at once? I think I have zeroed in on the code that will do this but, I can't seem to stick it where it needs to go to work without getting the error above.
For Each oSheet In oDoc.Sheets 'ENTER RULES HERE Next
