iLogic Errors for Center/Arrange Dimensions on All Sheets
3 REPLIES 3
624 Views, 3 Replies
Hello Everyone,
I am running into an issue with some code and I am hoping someone here can help me.  I am trying to create an iLogic rule (see bottom of this post) that will center and arrange dimensions on all sheets of a drawing.  While rummaging through this forum, I have found some code that does the trick.  (It's a bit of a Frankenstein's monster of two different code I found.)  Once I confirmed that this works in the current drawing, I copy and paste the rule in another drawing and try to run it.  Sometimes, the code will run fine in the new document.  most of the time, I get the following error.
Error Message Tab
Error in rule: Rule2, in document: DSFAB-XXX-001.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
More Info Tab
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.DrawingDimensions.Arrange(ObjectCollection DrawingDimensions, Object ContourEntity)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
I'm sure there is something wrong with my rule.  It's a merger of a "center dims" and "arrange dims" rule.  If any of you have a few moments to look through this and show me where I went wrong, I would be very grateful.
iLogic Code
Dim doc As Inventor.DrawingDocument = ThisDoc.Document
For Each sheet As Sheet In doc.Sheets
'sheet.Activate
Dim dimensions As Inventor.ObjectCollection = ThisServer.TransientObjects.CreateObjectCollection
Dim drawDim As Inventor.DrawingDimension
  For Each drawDim In sheet.DrawingDimensions
    If Not TypeOf drawDim Is Inventor.OrdinateDimensionSet _
      And Not TypeOf drawDim Is Inventor.BaselineDimensionSet _
      And Not TypeOf drawDim Is Inventor.ChainDimensionSet Then
     dimensions.Add(drawDim)
    End If
  Next
  sheet.DrawingDimensions.Arrange(dimensions)
Next
'Set a reference To the active drawing document
    Dim odoc As Document
    odoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet
    Dim oSheet As Sheet
    For Each oSheet In oDoc.Sheets
    Dim oDrawingDim As DrawingDimension
' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
For Each oDrawingDim In oSheet.DrawingDimensions
        If TypeOf oDrawingDim Is LinearGeneralDimension Or _
           TypeOf oDrawingDim Is AngularGeneralDimension Then
             oDrawingDim.CenterText
        End If
    Next
    Next
I am running Inventor 2016
3 REPLIES 3
This is the code I am currently running to arrange all dimensions. Hope it helps in some small way.
SyntaxEditor Code Snippet
'define application
Dim oApp As Application
oApp = ThisApplication
'define active doc
Dim oDoc As DrawingDocument
oDoc = oApp.ActiveDocument
'get dims
Dim oDims As DrawingDimensions
oDims = oDoc.ActiveSheet.DrawingDimensions
'create dim collection
Dim oDimCol As ObjectCollection
oDimCol = oApp.TransientObjects.CreateObjectCollection
'step through all dims one at a time
Dim oDim As DrawingDimension
For Each oDim In oDims
    If TypeOf oDim Is LinearGeneralDimension _
	Or TypeOf oDim Is AngularGeneralDimension Then
       oDim.CenterText 'center the dim
       oDimCol.Add(oDim) 'add the dim to collection
    End If
Next
'arrange the collection of dims
oDims.Arrange(oDimCol)
Thank you.  Your rule is much cleaner and easier to understand than mine is.  Any idea if it is possible to make this work on all sheets in a drawing at once?  I think I have zeroed in on the code that will do this but, I can't seem to stick it where it needs to go to work without getting the error above.
'ENTER RULES HERE
Next
PCP7
How do I make the same rule work for selected few sheets ?
Technology Administrators
