ilogic error: visual basic command line compiler stopped working
When I run any iLogic rule in any iam, I get this error (see attachments)..
I found an article (https://forums.autodesk.com/t5/inventor-general-discussion/avast-interfering-ilogic-rule/td-p/476424... but I don't use avast..
I could run the rules yesterday... Does anybody have any idea what may be causing the problem?
Thank you
Check to see if your PC installed any updates since it last worked. It sounds like something in your .NET install has got corrupted. if there was any updates then there should also be a restore point you could try taking it back to.
without having the error message translated is hard to offer decisive help.
Thank you very much! You were right. I just unistalled the updates and it worked.
no prob, glad it worked.
