Drawings with iLogic
Is there iLogic code that opens a new, blank drawing sheet based on the part where the rule was run?
Owner2229
Hi, you can try this:
Dim aScale As Double = 1 ' You can change the scale here
Dim oDoc As Document = ThisApplication.ActiveDocument Dim aDrawing As DrawingDocument aDrawing = ThisApplication.Documents.Add(kDrawingDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kDrawingDocumentObject)) Dim oSheet As Sheet = aDrawing.Sheets.Item(1) Dim TG As TransientGeometry = ThisApplication.TransientGeometry Dim aPoint As Point2d = TG.CreatePoint2d(0, 0) Dim oView As DrawingView
oView = oSheet.DrawingViews.AddBaseView(oDoc, aPoint, _
aScale, ViewOrientationTypeEnum.kFrontViewOrientation, _
DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
