Can I Put iProperties in Parts List Heading?
Check out the attached screenshot. I'd like to use several iProperties in the Heading for my Parts List. I tried calling them up as per standard protocol, but it doesn't seem to be working. My instincts tell me that it's not possible: you have to put in a "dumb" Heading. Is there a way to call up the iProperties (and perhaps even other properties or parameters) in my heading?
Thanks!
You can make iLogic rule that is triggered to run before save, so it would be fully automatic and user friendly.
Rule should just read the values from iProperties and override the part list title.
I'm unaware of any functions in iLogic that specifically write to the Parts List Heading. Do you know what they are?
Here is how you can access partslist title.
SyntaxEditor Code Snippet
Dim oApp As Inventor.Application
oApp = ThisApplication
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = oApp.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
Dim oPartslist As PartsList
oPartslist = oSheet.PartsLists.Item(1)
oPartslist.Title = "test"
