Need som starting guideance to offset page numbering on IDW sheets
JDidrik
JDidrik
Im not very experienced with programing, therefore I need some guidence to get started on a solution to a problem I have.
I need to overide the page number of my drawings sheets, normally Inventor starts at page 1, but my drawings (100 pages) shall be part of a larger document, and therefore I have to offset the pagenumbers. My drawings shall be page 20 -> in the document. I am thinking that the best  solution is to create a prompted entry in the  title block which by either iLogic or VBA is overwrited. I allready have an iLogic form which filles out most of my titleblock, so maybe I can add a field there which reflects what page number shall be on sheet 1. My code must also skip page numbering on all sheets which is exluded from print.
I would be very gratefull if someone could give me a hint on where to start to solve this problem 🙂
Jan Didrik
I think something like this might work for you. This is VBA.
Create a prompted entry textbox to title block. Prompted entry text to be "PageNumber".
Sub PageNumbers()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = oApp.ActiveDocument
Dim intPageNum As Integer
intPageNum = InputBox("Page number start:", "Page numbers")
Dim oSheet As Sheet
Dim oTitleBlock As TitleBlock
Dim strPromptedText As String
strPromptedText = "PageNumber" 'this is prompted entry test in the titleblock
Dim oTxtBox As TextBox
For Each oSheet In oDrawingDoc.Sheets
     If oSheet.ExcludeFromCount = False Or oSheet.ExcludeFromPrinting = False Then
        Set oTitleBlock = oSheet.TitleBlock
        For Each oTxtBox In oTitleBlock.Definition.Sketch.TextBoxes
             If oTxtBox.Text = strPromptedText Then
               Call oTitleBlock.SetPromptResultText(oTxtBox, intPageNum)
        Next
    intPageNum = intPageNum + 1
Next
End Sub
JDidrik
Thanks!
I asked for some starting guideance and you gave me the solution 😄
Jan Didrik
