iLogic Design Copy suffix replacement
Frank-Oosterwaal
Frank-Oosterwaal
Hello everyone,
First off, I'm looking for a answer without the use of Vault, which I know can solve this problem.
I use the iLogic design copy tool to make copies of my master models and add a suffix for unique file naming. The suffix is always the project number. This works great and is exactly what I need, but.....
Allot of times it makes more sense to copy one of the projects instead of the master. I can make a copy of the project but the ilogic design copy tool can't replace the suffix so I end up with a double (or more when copying a copy) suffix.
Example
This is what I want the filenames to look like (and happens when I'm copying from the master):
Assembly01-P173001.iam
This is what happens when I'm copying a project:
Assembly01-P173001-P173002.iam
I'm wondering if there is a rule which uses the iLogic desig copy tool and replaces the suffix instead of adding. Or maybe there's another way of achieving this?
Thanks in advance.
bradeneuropeArthur
Here you can find another copy design tool.
You first need to install the SDK tools.
C:\Users\Public\Documents\Autodesk\Inventor 2018\SDK\UserTools\CopyDesign\Bin
Second option is to write your own code regarding Copy design "With Replace String".
We have written a add in  for this, It is not that complicated.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
w.pepping
In a couple of weeks I have a new App available that does exactly what you want and more.
See the post on: Matprop
Get control of your sheet metal files.
Download the app from matprop.com
Frank-Oosterwaal
Hi @bradeneuropeArthur,
I thought about your first option before but it doesn't do what I need it to do. The second option is the one I was thinking off but what I was wondering is if anyone knows if it's possible to call the I-logic Design Copy tool in a rule. Something like you do when exporting 3d pdf and call for the addin.
Hi @w.pepping,
Sounds promising! Will keep an eye on that.
