Ilogic code, export all sheet metal as dxf in folder and write file name on dxf for graving
sebastian_duerrenmatt2TK7V
Message 1 of 24
Hi guys,
I`m searching desperatly for an Ilogic code to export dxf files from all sheet metal parts in an assembly. I`ve found some codes in the forum but i need in addition that the file name of the sheet metal part gets written on an edge of the dxf sheet metal unwinding. We`re chaning from Autodesk Advance to Inventor in our company.
Thanks a lot for your help!
In the attachment you`ll find an example from Advance how the exported dxf file should look like. There ist just the positionnumber but the whole file name would be better anyway.
Replies (23)
Message 21 of 24
marcin_otręba
you can use below code to export to selected folder with part number placed in dxf file:
Imports System.Windows.Forms
Dim
ass As AssemblyDocument = ThisDoc.Document On Error Resume Next OpenAt = "C:\" ' give your own starting location Dim dialog = New FolderBrowserDialog() ' declare folder picker dialog.SelectedPath = OpenAt ' give starting location If DialogResult.OK = dialog.ShowDialog() Then ' show folder picker and if button "ok was clicked export dxf's to picked location For Each ofile As Document In ass.AllReferencedDocuments dxffilename = "" If ofile.ComponentDefinition.Type = kSheetMetalComponentDefinitionObject Then Dim oSheetMetalCompDef As SheetMetalComponentDefinition = ofile.ComponentDefinition Dim fp As FlatPattern If oSheetMetalCompDef.HasFlatPattern = False Then oSheetMetalCompDef.Unfold oSheetMetalCompDef.FlatPattern.ExitEdit End If fp = oSheetMetalCompDef.FlatPattern nnname = ofile.PropertySets.Item(3).Item("Part Number").Value dxffilename =dialog.SelectedPath & "\" & nnname &".dxf" fp.Edit() Dim oSketch As PlanarSketch Dim oSketches As PlanarSketches Dim oTextBox As Inventor.TextBox oSketches = fp.Sketches Dim oFace As Face = fp.TopFace Dim oTransGeom As TransientGeometry = ThisApplication.TransientGeometry oSketch = oSketches.Add(oFace, False) If oSketch.NaturalAxisDirection = True Then MessageBox.Show(oSketch.NaturalAxisDirection, "Title") oTextBox = oSketch.TextBoxes.AddFitted(oTransGeom.CreatePoint2d(0.5, 1.2), nnname) End If If oSketch.NaturalAxisDirection = False Then oTextBox = oSketch.TextBoxes.AddFitted(oTransGeom.CreatePoint2d(0.5 + 6.4, -1.2), nnname) oTextBox.Rotation = 4 * Math.Atan(1) End If oTextBox.ConvertToGeometry("dim") oSketch.ExitEdit() Dim oDataIO As DataIO = ofile.ComponentDefinition.DataIO Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=R12&SimplifySplines=true&FeatureProfilesUpLayerCOLOR=255;255;0&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_TANGENT;IV_ARC_CENTERS;IV_FEATURE_PROFILES_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ROLL;" oDataIO.WriteDataToFile(sOut, dxffilename) oSketch.Delete End If Next End If
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
Message 22 of 24
marcin_otręba
hi @rzsla  i didin't manage to do it because it will consume to much effort. I do not know if it is even possible because you should analyse it line by line if it doesn't interact with anything elese, even if you do it then is some chanse that it will be placed inside some cutout without interation with enything else.
I think that best way it could be to create extrude and check affected features - but it must be done in model space. then you could get some results.
Ideas
or check my apps:
Message 23 of 24
frank5838S
Thank you, that worked!
For each part I get this message:
How can I avoid this?
Message 24 of 24
marcin_otręba
remove:
Ideas
or check my apps:
