iLogic - CASE Statement Help
arkelec
arkelec
As a rookie in Inventor VBA & iLogic, can I ask for a quick steer on the right approach to solve what I think is a fairly simple problem.
I need to set a dimension in an iPart to be conditional on the "Length" parameter (this is the actual parameter name).
I have some other parameters, one of which is used as the dimension in question, it's called "Dist_1".
Dist_1 will be either of two values:
Condition 1: 0
Condition 2: The result of another calculated formula within the iPart parameters
The iPart has 20 or so different lengths programmed into it. For every length which is a multiple of 100mm, I need to set Dist_1 to condition 2. For all others, condition 1.
A bit of net trawling suggest using the CASE function. I have created an iLogic rule containing the following code:
Select Case Length
Case "100"
Dist_1 =Dist_2
Case "200"
Dist_1 =Dist_2
Case "300"
Dist_1 =Dist_2
Case "400"
Dist_1 =Dist_2
Case "500"
Dist_1 =Dist_2
Case "600"
Dist_1 =Dist_2
Case "700"
Dist_1 =Dist_2
Case "800"
Dist_1 =Dist_2
Case "900"
Dist_1 =Dist_2
Case "1000"
Dist_1 =Dist_2
Case "1100"
Dist_1 =Dist_2
Case "1200"
Dist_1 =Dist_2
Case "1300"
Dist_1 =Dist_2
Case "1400"
Dist_1 =Dist_2
Case "1500"
Dist_1 =Dist_2
Case Else
Dist_1 =0
End Select
Clicking Save & Run does not generate any errors but assuming the above is correct, I'm not sure what to do next.
Some questions:
  1. Is the syntax for the length values correct (are the " " needed & do I need to specify the units used in the parameter setting - i.e. mm)?
  2. How do I link the dimension in the sketch to the output of the iLogic rule?
Thanks 🙂
MechMachineMan
1. The quotation marks depend entirely on what data type you are comparing. Given that it LOOKS like you are using Length as a parameter, I believe that means it's type will be "DoubleForEquals". Not sure what this means for the results of your code, but you can always write a simple example program to test it out.
2. Get the rule to set the PARAMETER, and have go into your sketch and make it reference that PARAMETER, like intended.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
arkelec
Thanks for replying.
I'm not sure what point one of your answer means but agree it can be tested.
This is the bit I can't seem to work out - "Get the rule to set the PARAMETER".  How & where is this done?
Dist_1 & Dist_2 are already parameters (user defined) & the sketch dimension (d27) already references Dist_1.
I assume that this will all work with an iPart?
arkelec
OK, I think the problem might lay with updating.
In the "Driving Rule" column in the parameters box, it lists the name of the rule I created.
I also created a form with the parameter "Length" visible so when I change that from 500 to 550mm, the DIST_1  value changes from Dist_2 to 0 (as per the rule code).
But when I "Change Component" in an assembly, the 0 value (Dist_1 parameter) is not updated.
Edit:
There is something else wrong.  It seems Dist_1 is either equal to Dist_2 or 0, but not both when there are two or more instances of the iPart in the same assembly.
rossano_praderi
I just would like to give you an alternative to "Select case" only for your information.
This is an "if" operator also called "ternary" with which you can get a shorter syntax for your code.
(https://docs.microsoft.com/en-us/dotnet/visual-basic/language-reference/operators/if-operator)
I'm also used the "mod" operator to check if the given number is a multiple of 100.
(https://docs.microsoft.com/en-us/dotnet/visual-basic/language-reference/operators/mod-operator)
Dist_1 = If((Val(Lenght) Mod 100) = 0, Dist_2, 0)
This doesn't solve your last question but can be helpful to make more readable your code.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
