Hi Guys,
TLDR: Code to only update sheets that require update
I'm using iLogic to go through all of the sheets in my idw to find unattached annotation and then activate the sheet and return so that I can reattach or delete the dimension. It works quite well right now but I've found that it is only able to find annotations that are on updated sheets. I fixed that problem by adding code to update the sheets before it finds the unattached dimensions but now it takes much longer because it updates every sheet in my set even if it doesn't require update. Is there a snippet that I can put into my rule so that when it goes through the sheets it only activates sheets that have the red lightning bolt?
Thank you for reading!
