Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
I want to change the whole assembly parts appearance using vba
1 REPLY 1
k14348
454 Views, 1 Reply
Hi Sergio,
            I have one main assembly, In that i have 4 sub assemblies and Main Parts. Sub assemblies also have some parts.
Now i would like to change part appearance for each part. I have a code which you have given for one part.
Public Sub SetYellowPartColor()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    ' Get a reference to the RenderStyle named "Red".
    Dim oRenderStyle As RenderStyle
    Set oRenderStyle = oPartDoc.RenderStyles.Item("Yellow")
    ' Assign the render style to the part.
    oPartDoc.ActiveRenderStyle = oRenderStyle
    ' Force the view to update to see the change.
    ThisApplication.ActiveView.Update
End Sub
Now i would like to do this for each components in assembly.
Could you please help me on this.
1 REPLY 1
Sergio.D.Suárez
in reply to: k14348
Sorry for taking a long time to answer, I think that for an assembly the same code could be applied as shown below.
Sub Change_All_PartColor()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    Set oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    Set oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        On Error Resume Next
        Dim oDoc As Document
        Set oDoc = oOcc.Definition.Document
            ' Get a reference to the RenderStyle named "Yellow".
        Set oRenderStyle = oDoc.RenderStyles.Item("Yellow")
        oDoc.ActiveRenderStyle = oRenderStyle
    Next
End Sub
I hope it will help you solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Technology Administrators
