ArrayList Compile error: Sub or Function not define
snappyjazz
snappyjazz
I'm using Inventor 2019 and using the vba editor. My code is to try and get the child nodes of the content center hierarchy. The code works when looping through and posting a message box at each loop. Now I would like to capture the display name of each child node in a list. However, at the "Dim NodeArrayList As New ArrayList" line I get the compile error. When reviewing that call to online help, it should work. Any suggestions?
Sub RecursiveNodes()
    Dim cc As ContentCenter
    Set cc = ThisApplication.ContentCenter
'    For Level1 = 1 To cc.TreeViewTopNode.ChildNodes.Count
    For Level1 = 1 To 2
'        MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).DisplayName)
        NodeArrayList.Add (cc.TreeViewTopNode.ChildNodes.Item(Level1).DisplayName)
                For Level2 = 1 To cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Count
'                        MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).DisplayName)
                        NodeArrayList.Add ("    " & cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).DisplayName)
                            For Level3 = 1 To cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Count
'                                MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).DisplayName)
                                NodeArrayList.Add ("    " & "    " & cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).DisplayName)
                                    For Level4 = 1 To cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).ChildNodes.Count
'                                        MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).ChildNodes.Item(Level4).DisplayName)
                                        NodeArrayList.Add ("    " & "    " & "    " & cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).ChildNodes.Item(Level4).DisplayName)
                                    Next
                            Next
                Next
    Next
'Message box to verify the hierarchy Dim NodeArrayListVariable As String If NodeArrayList.Count > 0 Then For Each Counter In NodeArrayList NodeArrayListVariable = NodeArrayListVariable & NodeArrayList(Counter) & vbNewLine Next Else MsgBox ("Node Array List wasn't created") End If MsgBox (NodeArrayListVariable) End Sub
snappyjazz
Update:
  • I was able to get the ArrayList created as a variable.
  • The line of code: "NodeArrayList.Add (cc.TreeViewTopNode.ChildNodes.Item(Level1).DisplayName)" gives a runtime error "Object required".  I didn't think it mattered what you added to an array list.
  • So I adjusted this line to: "NodeArrayList.Add (cc.TreeViewTopNode.ChildNodes.Item(Level1))". This is looking directly at the child node object itself. Now I have a runtime error "Object doesn't support this property or method".
Conclusion:
  • Am I setting the ArrayList incorrectly?
  • If I can't add the display name or the object directly to an array list via the ".add" method; is there another way? All the reading I have done supports the way I tried. I am missing something.
    Public NodeArrayList = ArrayList
    For Level1 = 1 To 2
'        NodeArrayList.Add (cc.TreeViewTopNode.ChildNodes.Item(Level1).DisplayName)
NodeArrayList.Add (cc.TreeViewTopNode.ChildNodes.Item(Level1)) For Level2 = 1 To cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Count ' MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).DisplayName) ' NodeArrayList.Add (" " & cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).DisplayName) For Level3 = 1 To cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Count ' MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).DisplayName) ' NodeArrayList.Add (" " & " " & cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).DisplayName) For Level4 = 1 To cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).ChildNodes.Count ' MsgBox (cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).ChildNodes.Item(Level4).DisplayName) NodeArrayList.Add (" " & " " & " " & cc.TreeViewTopNode.ChildNodes.Item(Level1).ChildNodes.Item(Level2).ChildNodes.Item(Level3).ChildNodes.Item(Level4).DisplayName) Next Next Next Next Dim NodeArrayListVariable As String If NodeArrayList.Count > 0 Then For Each Counter In NodeArrayList NodeArrayListVariable = NodeArrayListVariable & NodeArrayList(Counter) & vbNewLine Next Else MsgBox ("Node Array List wasn't created") End If MsgBox (NodeArrayListVariable) End Sub
