Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
I am getting an error exporting an Excel custom material BOM using iLogic I need help
8 REPLIES 8
Message 1 of 9
ngtatsang98
336 Views, 8 Replies
I'm having trouble exporting a custom Bill of Materials. Because I'm new to ilogic, I don't understand much about it. I have attached the code and error image when running the code below. Any help is helpful.
8 REPLIES 8
Message 2 of 9
Frederick_Law
in reply to: ngtatsang98
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-BE996AA3-DE49-4765-86A7-129DD7B42A4A
You have "Logger.Trace".
Don't run in "Trace".
Run in "Info" and change it to "Logger.Info".
Message 3 of 9
ngtatsang98
in reply to: Frederick_Law
It doesn't seem to work. I tried it. Can you help me fix the code? I'm new to it so I don't understand it very well other than copying and pasting to run the code
Message 4 of 9
Frederick_Law
Hmmm are you running iLogic?
Your screen shot doesn't looks like iLogic.
Change Log Level to "Info":
Message 5 of 9
ngtatsang98
yes i am running it
Message 6 of 9
@ngtatsang98
The logger was added to Inventor 2019.1.
If you are using an older version than 2019, you can just delete all the lines that start with Logger, and the code should still work.
If you are using Inventor 2019 without any updates, then you can install the 2019.1 update and then the code should run with the Logger lines.
I hope this helps.
Curtis
Message 7 of 9
Frederick_Law
Which version IV are you using?
Try comment out lines with Logger.
Message 8 of 9
It's great it works I use the 2018 version. I have a request that I need to add a bomb structure column in the Excel spreadsheet. How do I edit the code to separate the purchase details from other details?
Message 9 of 9
ngtatsang98
Technology Administrators
