HRESULT: 0x80004005 (E_FAIL) during API execution of assembly constrain
2 REPLIES 2
bartlomiej.czarniakBNLBF
347 Views, 2 Replies
I'm playing with API vb.net code in Visual Studio and I faced error that stoped me progressing and I don't know how to solve it. Maybe someone has idea.
I'm running code in assembly with 2 parts. I want only constrain it with mate constrain by origin planes of each part. Code below gives me HRESULT: 0x80004005 (E_FAIL).
  Dim oAssyDoc As Inventor.AssemblyDocument
        oAssyDoc = invApp.ActiveDocument
        Dim oCompDef As Inventor.AssemblyComponentDefinition
        oCompDef = oAssyDoc.ComponentDefinition
        Dim oPartFlange As Inventor.ComponentOccurrence
        oPartFlange = oCompDef.Occurrences.Item(1)
        Dim oPartPipe As Inventor.ComponentOccurrence
        oPartPipe = oCompDef.Occurrences.Item(2)
        Dim BaseYZ As Inventor.WorkPlane
        BaseYZ = oCompDef.WorkPlanes.Item(1)
        Dim BaseYZPipe As Inventor.WorkPlane
        BaseYZPipe = oPartPipe.Definition.WorkPlanes.Item(1)
        Dim BaseYZFlange As Inventor.WorkPlane
        BaseYZFlange = oPartFlange.Definition.WorkPlanes.Item(1)
        'MsgBox("test " & BaseYZPipe.Name)
        oCompDef.Constraints.AddMateConstraint(BaseYZFlange, BaseYZPipe, 0)
 Code works well, I can read names of occurances in assembly, but it failes on constraining. I will appriciate any help.
Labels (1)
  • API
2 REPLIES 2
@bartlomiej.czarniakBNLBF
Please note that whenever you are using something from Occurrences (i.e. Work plane, Face, Work Axis, etc.) you need to create a proxy, If you are using something from the active assembly, the proxy is not needed. See below code.
		Dim oWP1 As WorkPlaneProxy
		Dim oWP2 As WorkPlaneProxy
		oPartFlange.CreateGeometryProxy(BaseYZFlange, oWP1)
		oPartPipe.CreateGeometryProxy(BaseYZPipe, oWP2)
                 oCompDef.Constraints.AddMateConstraint(oWP1,oWP2,"0")
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Wow! That was it! Thank you very much, I didn't have a clue about those proxy geometries. Is this applicable for axis and planes of solids as well?
Technology Administrators
