Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Weird Error Message
4 REPLIES 4
301 Views, 4 Replies
Weird Error Message
So I'm editing this piece of code to switch materials in my parts.  and I get this Error message (its in my language i'm afraid)
Code:
'Actieve assembly selecteren (selecting Assembly)
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
'Materiaal naar parts (Material to parts)
Dim strMaterialName As String
strMaterialName = "_SS 316L" & "_FRP"
Dim oMaterial As Material
On Error Resume Next
'Materiaal pakken (take material)
oMaterial = oAsmDoc.Materials.Item(strMaterialName)
On Error GoTo 0
'door alle parts gaan (go through all parts)
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
' kijken of het een part is (check if part)
If oDoc.DocumentType = kPartDocumentObject Then
Dim oPartDoc As PartDocument
oPartDoc = oDoc
' materiaal instellen
oPartDoc.ComponentDefinition.Material = oMaterial
Next
and the message I get is this:
If someone can help me identifying what the error is then I'll give you a imaginary case of beers 😉
4 REPLIES 4
WCrihfield
1)  An assembly doesn't have a set 'material', only parts do.
2)  An AssemblyDocumet object doesn't have a 'Materials' property that can be accessed.  It does however have a 'MaterialAssets' property.  Maybe try changing the variable Type to MaterialAsset, then setting its value like oAsmDoc.MaterialAssets.Item(strMaterialName).
3)  You interrupt error checking just long enough to try to get the material asset, then resume normal error checking right afterwards, but what if it doesn't find that material asset...It will then throw an error anyways.  Try enclosing that line of code that gets the material asset within a Try...Catch...End Try block of code, then in the Catch portion of it, put a MsgBox and/or Exit Sub or Return.
4) Neither the PartDocument, nor the PartComponentDefinition have a Property called 'Material'.  The PartDocument has a MaterialAssets Property, similar to the AssemblyDocument, however, the PartDocument does have an 'ActiveMaterial' Property, that you can set an Asset (or a MaterialAsset) as its value.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
in reply to: WCrihfield
@Anonymous
Try this version of the code:
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim strMaterialName As String = "_SS 316L_FRP"
Dim oMaterial As MaterialAsset
Try
	oMaterial = oAsmDoc.MaterialAssets.Item(strMaterialName)
Catch
	MsgBox("Didn't find a Material Asset with that name. Exiting.", , "")
	Exit Sub
End Try
		Dim oPartDoc As PartDocument = oDoc
		Try
			oPartDoc.ActiveMaterial = oMaterial
		Catch
			MsgBox("Cound't change material for the following part:" & vbCrLf & _
			oPartDoc.FullDocumentName,,"")
		End Try
Next
Wesley Crihfield
Yes!
Thank you very much
I owe you a imaginary case of beers hahaha
Ralf_Krieg
Hello
Am I right that your code assumes that the material asset is in the assembly document and all part documents or it  fails? Wouldn't it be better to only check if material asset is in the actual material setting part and if not try to copy it from the actual material library?
If so, I would suggest tthe following, else correct me please. 🙂
'Actieve assembly seleceren (selecting Assembly)
Try
    oMaterial = ThisApplication.ActiveMaterialLibrary.MaterialAssets.Item(strMaterialName)
Catch
End Try
Dim oMatAsset As MaterialAsset
		oPartDoc=oDoc
		Try
        	oMatAsset = oPartDoc.MaterialAssets.Item(strMaterialName)
		Catch
			If oMaterial Is Nothing Then
				MsgBox("Material " & strMaterialName & " not found. Exit",,"iLogic")
				Exit Sub
			oMatAsset = oMaterial.CopyTo(oPartDoc, False)
        End Try
			oPartDoc.ActiveMaterial = oMatAsset '.ComponentDefinition.Material = oMaterial
Next
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
Technology Administrators
