How to NOT run an "After Open Document" rule event trigger?
I have mistakenly created a monster!
I have many drawing files that run a rule on the trigger "After Open Document", but I have a minor, but costly, error in this rule (local rule in each file, copied from template).
Is there a way to open a file, but defer any triggers or rules from running?
(The rule was supposed to defer updates. My mistake is that it un-defers and thus updates the model, ruining the drawing.)
MechMachineMan
If you use FastOpen through the API, it should leave the model disconnected from the drawing, which should give you time to change things.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-44DDD7C9-D90E-4F49-BEE2-757EE785C826
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
That seems like it would work, but I am a hopeless Copy-Jockey when it comes to iLogic
Dim oFileDlg As Inventor.FileDialog = Nothing
Call ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
Call oFileDlg.ShowOpen()
Documents.OpenWithOptions( oFileDlg.FileName, FastOpen, True)
I'm sure I need to Dim [something] As [whoknows] for the Documents part to work, but my mind has just melted.
I would be grateful if you could help me with what I need to make this work.
MechMachineMan
SyntaxEditor Code Snippet
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Add("FastOpen", "true")
ThisApplication.Documents.OpenWithOptions(oFileDlg.FileName, oOptions, True)
Justin K
Wahoo!! Thank you for saving my melting brain!!
