I am trying to create an iLogic rule which will sift through assemblies and extract information from the iProperties and export it to an excel spreadsheet.I have leveraged heavily off of a previous forum post which wants to do something similar: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/iproperties-export-to-excel/td-p/921...
I have a number of folders that I do not want to search through in the directory, such as OldVersions in the forum post above. The rule works great for excluding folders without and spaces in the name, but it won't run if I try to search for folders with a space.
I made a test folder where I have some parts and three folders: "OldVersions", "TestFolder" and "Test Folder" each with parts in them to try debug it. Using the following lines of code will ignore the parts in OldVersions and TestFolder, and find the part in Test Folder:
For Each File As IO.FileInfo In Folder.GetFiles("*.ipt",IO.SearchOption.AllDirectories) If File.FullName.Contains("OldVersions" ) = False Then If File.FullName.Contains("TestFolder") = False Then FileList.Add(File.FullName) End If End If Next
I want to exclude all 3 folders, and tried the following lines of code:
For Each File As IO.FileInfo In Folder.GetFiles("*.ipt",IO.SearchOption.AllDirectories) If File.FullName.Contains("OldVersions" ) = False Then If File.FullName.Contains("TestFolder") = False Then If File.FullName.Contains("Test Folder") = False Then FileList.Add(File.FullName) End If End If End If Next
However this fails to run, I think the rule gets to the line with "Test Folder" then cancels. How do I define folder names with the spaces?
Thanks in advance
Solved by Curtis_Waguespack. Go to Solution.
Hi @Thomas1365,
Is there a specific reason why you are using .contains intead of equal ? If you are looking for specific folder name, I would do it like this (and also cleaning the code with guard clauses) :
For Each File As IO.FileInfo In Folder.GetFiles("*.ipt",IO.SearchOption.AllDirectories) If File.FullName = "OldVersions" Then Continue For If File.FullName = "TestFolder" Then Continue For If File.FullName = "Test Folder" Then Continue For FileList.Add(File.FullName) Next
Does this suits your needs ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Thanks for the response @FINET_Laurent,
I think that's a better approach, however I do want to exclude those files so I tried:
For Each File As IO.FileInfo In Folder.GetFiles("*.ipt",IO.SearchOption.AllDirectories) If File.FullName Is Not "OldVersions" Then Continue For If File.FullName Is Not "TestFolder" Then Continue For If File.FullName Is Not "Test Folder" Then Continue For FileList.Add(File.FullName) Next
However it didn't work. Is it a syntax issue on my end?
Hi @Thomas1365,
I think it is indeed an issue on your side. You should replace the "Is Not" statement with a simple " = " as I did, and I suppose it will do the trick. To understand this better, here is some lecture :
Continue Statement - Visual Basic | Microsoft Learn
Kind regards,
FINET L.
If this post helped out in any way to solve your question, please drop a "Like"Hi @Thomas1365 and @FINET_Laurent
I think contains is required here, because File.Fullname is returning the file path.
You could use something like this:
Dim Folder As New IO.DirectoryInfo("C:\Temp") Dim FileList As New List(Of String) For Each File As IO.FileInfo In Folder.GetFiles("*.ipt", IO.SearchOption.AllDirectories) If File.FullName.contains("OldVersions") Then Continue For If File.FullName.contains("TestFolder") Then Continue For If File.FullName.contains("Test Folder") Then Continue For FileList.Add(File.FullName) Next
or maybe something like this
Dim RootFolder As New IO.DirectoryInfo("C:\Temp") Dim FileList As New List(Of String) For Each oFolder As IO.DirectoryInfo In RootFolder.GetDirectories("*", IO.SearchOption.AllDirectories) If oFolder.Name = "OldVersions" Then Continue For If oFolder.Name = "TestFolder" Then Continue For If oFolder.Name = "Test Folder" Then Continue For For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.AllDirectories) FileList.Add(File.FullName) Next Next
Or even something like this:
Dim RootFolder As New IO.DirectoryInfo("C:\Temp") Dim FileList As New List(Of String) Dim ExcludeList = New String() {"OldVersions", "TestFolder", "Test Folder" } For Each oFolder As IO.DirectoryInfo In RootFolder.GetDirectories("*", IO.SearchOption.AllDirectories) If ExcludeList.Contains( oFolder.Name) Then Continue For For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.AllDirectories) FileList.Add(File.FullName) Next Next
I hope this helps.
Curtis
Thanks for your help @Curtis_Waguespack and @FINET_Laurent .
I liked the 3rd rendition the most as it's the cleanest and I can easily add more filenames to exclude (the real application has many more different file names and sub folders). This seems closer to working how I want, however it doesn't return the parts within the root folder.
I tried to solve this by taking the RootFolder up a level, however it then returns everything within the folder because (I believe) it's only checking for the "ExcludeList" the initial time and then adds it to the list. I think I need to add another layer to the For loop to check again within each folder.
I think it might help if I explain a bit better my testing folder arrangement:
So I know if I see the "I DONT WANT THIS" part it's looked in the wrong folder (I also have it returning the file directory to double check).
If I run the RootFolder as "S:\Testing\Macro Testing\Testing Folder" I will get no results in my exported excel, I believe this is because the script doesn't say to check in the RootFolder itself for .ipt files. So I changed the RootFolder to be a level up as: "S:\Testing\Macro Testing". This then returns every part including the "I DONT WANT THIS" as I mentioned.
I have tried to add another check for the ExcludeList after finding applicable folders:
Dim RootFolder As New IO.DirectoryInfo("S:\Testing\Macro Testing") Dim FileList As New List(Of String) Dim ExcludeList = New String() {"OldVersions", "TestFolder", "Test Folder"} For Each oFolder As IO.DirectoryInfo In RootFolder.GetDirectories("*", IO.SearchOption.AllDirectories) If ExcludeList.Contains(oFolder.Name) Then Continue For For Each oSubFolder As IO.DirectoryInfo In oFolder.GetDirectories("*", IO.SearchOption.AllDirectories) If ExcludeList.Contains(oSubFolder.Name) Then Continue For For Each File As IO.FileInfo In oSubFolder.GetFiles("*.ipt", IO.SearchOption.AllDirectories) FileList.Add(File.FullName) Next For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.AllDirectories) FileList.Add(File.FullName) Next Next Next
However this returns nothing when running the script. I think I need to better define to first look for parts in the first level of the folders, and then look at the folders, then ignore any from the ExcludeList.
Thanks so much for your help. This is my first time trying to make anything in iLogic and I also don't have any programming background, so I apologise if I'm missing obvious things.
Hi @Thomas1365,
Try this version. It first gets a list of folders, then looks through those folders for files
I hope this helps.
Curtis
Dim RootFolder As New IO.DirectoryInfo("C:\Temp") Dim FileList As New List(Of String) Dim ExcludeList = New String() {"OldVersions", "TestFolder", "Test Folder" } Dim FolderList As New List(Of IO.DirectoryInfo) 'add root folder FolderList.Add(RootFolder) 'get sub folders For Each oFolder As IO.DirectoryInfo In RootFolder.GetDirectories("*", IO.SearchOption.AllDirectories) If ExcludeList.Contains(oFolder.Name) Then Continue For FolderList.Add(oFolder) Next For Each oFolder In FolderList For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.TopDirectoryOnly) FileList.Add(File.FullName) Next Next
That works! Fantastic. Thank you very much.
I have added another layer to the smarts of the script to eliminate parts from the list I do not want to open. I've achieved this by adding another string for "ExcludeListParts", below removed Cube 2 from being added to the file list:
Dim RootFolder As New IO.DirectoryInfo("S:\Testing\Macro Testing") Dim FileList As New List(Of String) Dim ExcludeList = New String() {"OldVersions", "TestFolder", "Test Folder"} Dim ExcludeListParts = New String() {"Cube 2.ipt"} Dim FolderList As New List(Of IO.DirectoryInfo) 'add root folder FolderList.Add(RootFolder) 'get sub folders For Each oFolder As IO.DirectoryInfo In RootFolder.GetDirectories("*", IO.SearchOption.AllDirectories) If ExcludeList.Contains(oFolder.Name) Then Continue For FolderList.Add(oFolder) Next For Each oFolder In FolderList For Each File As IO.FileInfo In oFolder.GetFiles("*.ipt", IO.SearchOption.TopDirectoryOnly) If ExcludeListParts.Contains(File.Name) Then Continue For FileList.Add(File.FullName) Next Next
Is there a way to eliminate a file with a certain key word from being added to the list?
