How to disable Form Inputs in iLogic
Hello all,
I'm looking for a way to force a form to calculate an input based on a user selection.
See the images - easier to explain with pictures.
Hi @Anonymous!
to achieve that you could use a parameter (bool) and connect it with the Button/Dropdown or whatever.
Of course you could even control such a param by iLogic or VBA.
Find screenshots attachet of what I am trying to explain.
If this sounds good or you have any questioins, let m know 😉
bradeneuropeArthur
I assume you mean disabling textboxes and buttons etc like you can do in Vb.net forms and VBA forms.
I think this is not possible for I-logic, but I am not sure!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
