How to call a Excel form to inventor.
jeeva.scientist
jeeva.scientist
Hello everyone,
  1. I have a part model.
  2. Dimensions in the part model are driven my excel link.
  3. I have a form in excel, to change the values.
  4. I also have a form in the Part model.
  5. The excel file is located in the same folder as the part model.
Question:
  1. Is it possible to call the excel form from the part model form?
bradeneuropeArthur
With VBA;Vb.net; Ilogic or by referencing the table in the part directly?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
HideoYamada
You can call excel VBA macro from Inventor VBA macro.
Inventor VBA Code :
Sub test()
    Dim xlApp As Excel.Application
    Set xlApp = GetObject(, "Excel.Application")
' Here "ExcelSub" is the name of the Macro. xlApp.Run "ExcelSub" End Sub
You must add Reference to Excel Object Library in Inventor before use this code.
Excel VBA Code :
Public Sub ExcelSub()
    ' Get application focus
    AppActivate Application.Caption
    ' Show dialog
    UserForm1.Show
End Sub
The workbook must have been opened.
Let's try !!
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
jeeva.scientist
Thanks for your Support 👍
Working Proof 👇
