I have create this two rules but i have to regenerate menially the rules, does'nt it can be done automatycally
the rules are cut and paste from one of autodesk forums
thank you for your help
Solved by WCrihfield. Go to Solution.
Hi @hugo7. If I am understanding your request / questions, then there is a tool button for this functionality on the Manage tab, iLogic panel, where there is a button named "Regenerate All Rules". When you click that, it will run all of the unsuppressed internal iLogic rules within the current document, but will also run all unsuppressed internal iLogic rules within all of the other documents that are referenced within the current document. Part of its functionality though, is to fix broken links / associations between any blue, unquoted parameters that are being used in any of those internal iLogic rules, so the work correctly again. Their functionality can sometimes get 'broken' by deleting them, then recreating them, or creating the code before the parameter existed, and some other odd actions.
However, the below code shows you the 'ControlDefinition' behind that button, which we can find, then execute by code, to do the same thing as clicking that button. Be careful using that code routine though. It will act upon whichever document that is both active and visibly showing on your screen at the moment it runs.
Dim oRegenAllRules As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules")
oRegenAllRules.Execute2(True)
Wesley Crihfield
(Not an Autodesk Employee)
