Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Show only
Search instead for
Hi @CGVJM6DF. Can you please describe what is wrong in more detail? It looks like you have a SketchedSymbolDefinition with the same name in two places. One is already within your active document. The other one is stored within your "SketchedSymbols.idw" library file. You will only be able to get the one that is already located within your active document with that line of code. To access the other one (in your library file), you would have to use a different process to copy that version into your active document, and overwrite the one with the same name in your active document (SketchedSymbolDefinitions.AddFromLibrary). If you are getting an error message, then could you please tell us what the error message says?
