How do I run an external rule on all files in a folder?
Message 1 of 17
I have written an external rule that I need to run on ~3,000 files in a folder in a shared network location. I have nearly been successful using the following code (Batch Update)
Dim Folder As New IO.DirectoryInfo("folder with idw files to be processed")
Dim FileList As New List(Of String)
For Each File As IO.FileInfo In Folder.GetFiles("*.idw",IO.SearchOption.AllDirectories)
If File.FullName.Contains("OldVersions") = False Then
FileList.Add(File.FullName)
Next
i = MessageBox.Show(FileList.Count & " files were found", "File count", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
Dim oDoc1 As Document
Dim DocName As String
For Each DocName In FileList
oDoc1 = ThisApplication.Documents.Open(DocName, True)
MessageBox.Show(DocName, "Path and file name", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
iLogicVb.RunExternalRule("Batch - Update title block and border")
ThisDoc.Save
oDoc1.Close(False)
Next
This initially seemed to work, but for some reason, when each document is opened, iLogic cannot 'see' the file - the "Path and file name" message box returns nothing. As a result, the "Batch - Update title block and border" rule doesn't run as expected.
When the "Batch - Update title block and border" rule is manually run on a drawing, it works as intended, but whe called from the "Batch Update" rule it doesn't. When the "Batch - Update title block and border" rule gets to
Dim Sheet_Size As String = ActiveSheet.Size
 instead of setting Sheet_Size to equal A2/A3/A4/custom, it sets it to equal the size of the active page in the drawing the original "Batch Update" rule was run from.
How do fix this?
Replies (16)
Message 2 of 17
cadman777
CodeInjector on GitHub
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 3 of 17
WCrihfield
I made a couple of minor adjustments to your posted code, that may, or may not help some.
Next
For Each DocName As String In FileList
	Dim oDoc1 As Document = ThisApplication.Documents.Open(DocName, True)
	iLogicVb.Automation.RunExternalRule(oDoc1, "Batch - Update title block and border")
	oDoc1.Save2(False)
	oDoc1.Close(True)
Next
  But I would need to see the contents of the other rule in order to attempt to troubleshoot any potential issues that may be going on there.  Usually, in these types of situations, it has to do with how you specify which documents the code is supposed to be targeting (acting upon) that causes problems when running them remotely.  They may function just fine when there is just one document open and active, but when attempting to run it remotely, while another document may be open or active, you can start to run into reference problems.  Here is a contribution post I created some time past that goes into much more detail on the subject of document references.
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 17
Thanks for the link, I'll have a read and see if this helps.
The code within "Batch - Update title block and border" is as follows
Sub Main()
ThisDrawing.ResourceFileName = "\\pccox\DRAWINGS\Inventor\templates\SHEET REFORMAT MASTER.idw" 'document to copy title block and border from
Dim oDrawingDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
Dim oDrawing As DrawingDocument 'variable
oDrawing = ThisApplication.ActiveDocument 'variable
Sheet_Count = oDrawing.Sheets.Count 'variable
oDoc = ThisDoc.Document
Current_Sheet = oDoc.ActiveSheet.Name
Resize = "No"
oDrawingDoc.Activate
For SheetNumber = 1 To Sheet_Count 'for loop to run through each sheet in drawing
	oDrawingDoc.Sheets(SheetNumber).Activate 'activates sheet
	Sheet_Size = ActiveSheet.Size 'sets Sheet_size to equal the size of the active sheet (A2,A3,custom)
	ThisApplication.UserInterfaceManager.DoEvents
	If Sheet_Size = "A2"'checks if the sheet size is a custom size
		Resize = "No"
		i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In A2 branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	Else If Sheet_Size = "A3"'checks if the sheet size is a custom size
		Resize = "No"
		i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In A3 branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	Else
		Resize = "Yes"
		ThisApplication.ActiveDocument.ActiveSheet.Orientation  = kLandscapePageOrientation
		ActiveSheet.ChangeSize("A3", moveBorderItems := True) 'sets sheet to A3 - old template was 400x300mm, close to A3
		i = MessageBox.Show("Page resized!", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In custom branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	Sheet_Size = ActiveSheet.Size 'sets Sheet_size to equal the size of the active sheet (A2,A3)
	ActiveSheet.SetTitleBlock(Sheet_Size, "PLACEHOLDER - CHANGE ME", "PLACEHOLDER - CHANGE ME")'applies title block that corresponds to page size
	ActiveSheet.Border = Sheet_Size & " Border"'applies border to corresponding page size
Next SheetNumber'loops the above until all pages have been processed
 It all runs as expected when run manually in a drawing, but when called from the "Batch Update" rule above, the "Sheet_Size = ActiveSheet.Size" sets Sheet_Size to equal the size of the sheet that was active when "Batch Update" was run, instead of the active sheet in the drawing that has been opened
Message 5 of 17
tobias.orlow
Hi @Anonymous ,
you might also want to have a look at the following app within the App Store to automate the process of executing iLogic rules in multiple files in batch: iLogic Rule Batch Tool | Inventor | Autodesk App Store
Many thanks,
Tobias
Tobias Orlow
Designated Support Specialist
Customer Success Organization
Linkedin: www.linkedin.com/in/tobiasorlow/
Message 6 of 17
Hi @tobias.orlow, thanks for the link. Unfortunately the same issue happens with the iLogic Rule Batch tool as with my "Batch Update" external rule.
I need a way to use the
Sheet_Size = oDrawingDoc.ActiveSheet.Size
operation to look at the drawing that has been opened, instead of the drawing that the "Batch Update" rule was run from
Message 7 of 17
cadman777
Hey Tobias,
I looked at the app on the link you provided.
It looks a lot like MegaJerk's 'CodeInjector'.
Did you guys based your app on his?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 8 of 17
tobias.orlow
Hi @cadman777 ,
while some of the functionality is similar, the app is not based on the CodeInjector project in any way.
I found it would be helpful to provide an up-to-date tool to achieve such automations as they are valuable and the mentioned project is not maintained anymore.
Many thanks,
Tobias Orlow
Message 9 of 17
A.Acheson
You will need to make the drawing opened available for editing so you can use
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveEditDocument
The alternative would be to pass the full file path to the rule but that is more complicated for sure.
Regards
Alan
Message 10 of 17
WCrihfield
There are lots of potential for problems in that other code that I'm seeing that could definately be causing trouble when ran remotely like this.  It's going to take some time to comb down through it all and attempt to code some things differently, while maintaining its functionality.  Right from the start, it is creating 3 different variables for the document it is supposed to be working with, which I definitely don't recommend.  Then the repeated use of the shortcut term ActiveSheet, will need to be replaced with the equivalent object obtained from the document object, the longer way, because ActiveSheet wants to default to the 'local' document first, then to whichever document was active when the rule first started.  I don't mention this one in my references post, but I believe it is defined the same way as other similar reference terms are.  I believe the 'active' document reference may work for us in this situation, because your top rule is opening each drawing visibly, before attempting to run the rule, which should (theoretically) make that newly opened drawing document the 'active' document.  But since this is a batch run situation, I'm not sure if there may be a timing issue going on or not.
Wesley Crihfield
Message 11 of 17
WCrihfield
Well...I honestly don't recall how to do some of these things the 'long way', because I just never had to before.  First, I don't remember (or maybe never knew) how to set the 'ResourceFileName' data without using that document reference 'ThisDrawing', but I believe we need to do it somehow using our main/only document variable, instead of that reference.  Second, I don't recall having to re-associate things which might have been attached to the Border of a drawing to the new Border after changing the border.  This functionality is part of the ActiveSheet.ChangeSize  (link1, link2) method.  I know how to change the sheet's size, just not the re-associate stuff part.
Here's what I've got so far, but I'm not sure I've still got everything set up as you need it, so you may have to test it on a single drawing to start with, before attempting to run it in your batch process.
Sub Main()
	Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
	'I can't remember how to do this the 'long way'
	'oDDoc.ReferencedOLEFileDescriptors.Add("\\pccox\DRAWINGS\Inventor\templates\SHEET REFORMAT MASTER.idw", OLEDocumentTypeEnum.kOLEDocumentLinkObject)
	Current_Sheet = oDDoc.ActiveSheet.Name
	Resize = "No"
	'oDDoc.Activate 'it is already active, because of how we retrieved it
	For Each oSheet As Sheet In oDDoc.Sheets
		oSheet.Activate 'activates sheet
		Sheet_Size = oSheet.Size 'sets Sheet_size to equal the size of the active sheet (A2,A3,custom)
		If Sheet_Size = DrawingSheetSizeEnum.kA2DrawingSheetSize Then
			Resize = "No"
			MsgBox("Sheet size is " & Sheet_Size.ToString & vbCrLf & "In A2 branch", vbOKOnly + vbCritical, "Page size")
		ElseIf Sheet_Size = DrawingSheetSizeEnum.kA3DrawingSheetSize Then
			Resize = "No"
			MsgBox("Sheet size is " & Sheet_Size.ToString & vbCrLf & "In A3 branch", vbOKOnly + vbCritical, "Page size")
		Else
			Resize = "Yes"
			oSheet.Orientation = kLandscapePageOrientation
			oSheet.Size = DrawingSheetSizeEnum.kA3DrawingSheetSize
			'need code here to making sure border items get moved as originally planned
			'ActiveSheet.ChangeSize("A3", moveBorderItems := True) 'sets sheet to A3 - old template was 400x300mm, close to A3
			MsgBox("Page resized!", vbOKOnly + vbCritical, "My iLogic Dialog")
			MsgBox("Sheet size is " & Sheet_Size.ToString & vbCrLf & "In custom branch", vbOKOnly + vbCritical, "Page size")
		Sheet_Size = oSheet.Size 'sets Sheet_size to equal the size of the active sheet (A2,A3)
		Dim oTBDef As TitleBlockDefinition
		Dim oBDef As BorderDefinition
		If oSheet.Size = DrawingSheetSizeEnum.kA2DrawingSheetSize Then
			oTBDef = oDDoc.TitleBlockDefinitions.Item("A2")
			oBDef = oDDoc.BorderDefinitions.Item("A2 Border")
		ElseIf oSheet.Size = DrawingSheetSizeEnum.kA3DrawingSheetSize Then
			oTBDef = oDDoc.TitleBlockDefinitions.Item("A3")
			oBDef = oDDoc.BorderDefinitions.Item("A3 Border")
		oSheet.AddTitleBlock(oTBDef)
		oSheet.Border.Delete
		oSheet.AddBorder(oBDef)
	Next 'loops the above until all pages have been processed
End Sub
Wesley Crihfield
Message 12 of 17
cadman777
OK, thanx for the update.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 13 of 17
WCrihfield
Hi @Anonymous.  Here is one way (work-around) to avoid using the 'ThisDrawing.ResourceFileName' tool, that will still allow you to pull the needed resources from that template drawing file if needed.  It basically just opens that template drawing document 'invisibly' (in the background, without a tab), then extracts the title block definitions and border definitions from that document to two variables we can use later in the code.  Then later, when we don't need those resources anymore, closes that template file.  Opening and closing that template file shouldn't use much resources, since it is only being opened invisibly.
Dim oTemplatePath As String = "\\DIV29-FS-01\Shared\Engineering\Templates\A-Size Standard Drawing.idw"
Dim oTemplateDDoc As DrawingDocument = ThisApplication.Documents.Open(oTemplatePath, False) 'False = invisible
Dim oTemplateTBDefs As TitleBlockDefinitions = oTemplateDDoc.TitleBlockDefinitions
Dim oTemplateBDefs As BorderDefinitions = oTemplateDDoc.BorderDefinitions
'...your other code which pulls any needed resources from these sources...
'then close that template drawing document
oTemplateDDoc.Close(True) 'True = skip any possible attempts to save the Template when closing it
If you replaced that line of code with this block of code, then you would just need to use these two new variables down within your code, whenever you need to specify a title block or border to use, after a sheet size change.
You might also benefit from using a Boolean type variable as a flag, initially set to False. Then when looping through the sheets, if you had to change the sheet's size, set this variable to True. Then when it comes to the part of the code where you attempt to change the sheet's border and title block, you could check this variable.  If it is still False, then it won't need to attempt to change its border and title block.
Another thought would be to open this template document within the top (run the other rule) rule code, then just pass these two resources to the other rule that it is running, through the NameValueMap & RuleArguments route, so that you would only be opening and closing it one time for the whole batch run process.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
Message 14 of 17
So I got it working, with an irritatingly small change required
Now reads
oDoc1 = ThisApplication.Documents.OpenWithOptions(DocName, oOptions, True)
iLogicAuto.RunExternalRuleWithArguments(oDoc1, "Batch - Update title block and border", oArgs)
Where DocName is a string containing the full filepath of the drawing to be updated
I'm pretty sure the issue was the original call to run the "Batch - Updater title block and border" iLogic rule runs the rule inside the document which the first rule was run inside, which causes issues with ActiveSheet and ActiveDocument, where as the new call for for the iLogic rule tells inventor to run the rule inside a specific document, in this case DocName
Message 15 of 17
Full code now reads:
To replace title block and border, and place sketch symbols for all drawings in a folder
Batch Update
Sub Main()
'	On Error GoTo errtrap
	'setup to read in the log file
    Dim oFile As String = "Text file for report.txt"'must already exist
    Dim oReader As System.IO.StreamReader = New System.IO.StreamReader(oFile)
    Dim DoneList As String
    Dim line As String
    'read in log file
    Do
        line = oReader.ReadLine()
        DoneList = DoneList & line
    Loop Until line Is Nothing
    'close log for reader
    oReader.Close()
	Dim Folder As New IO.DirectoryInfo("Folder location containing all drawings to be updated")'Folder in which drawings to be updated are located
	Dim FileList As New List(Of String)'creates a list of files
	For Each File As IO.FileInfo In Folder.GetFiles("*.idw", IO.SearchOption.AllDirectories)'runs below "If" loop on every file with ".idw" file extension
		If File.FullName.Contains("OldVersions") = False Then'exludes all files that have "OldVersions" in their filepath from the next line
			'to exclude any files with a specific string of characters from being processed, remove the ' from the next 5 lines & change "Your Text here" to you character string
		'	If File.FullName.Contains("Your Text here") = False Then
		'		If File.FullName.Contains("OldVersions") = False Then
		'			FileList.Add(File.FullName)
		'		End If
		'	End if
			FileList.Add(File.FullName)'adds file to the list to be processed
	Next
	'display files found by search, exit if 0
    If FileList.Count > 0 Then
        MsgBox(FileList.Count & " files were found")
    Else
        MsgBox("No more files were found.  ")
        Exit Sub
	'Shows how many files have been found and will be processed - currently approx 2m30s per file
	'MessageBox.Show(FileList.Count & " files were found", "File count", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	Dim oDoc1 As Document'variable
	Dim oAppend As System.IO.StreamWriter
	 oAppend = IO.File.AppendText(oFile)
'	Try
  '  Catch
   '     GoTo Close
    'End Try
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	'change these to false if you need to open and update from model.
	oOptions.Value("DeferUpdates") = True
	oOptions.Value("FastOpen") = True
	For Each DocName As String In FileList'iterates through every file in the filelist
		Try
		'oDoc1 = ThisApplication.Documents.Open(DocName, True)'opens file
		Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument'variable to allow iteration through all sheets in each drawing
		ThisApplication.UserInterfaceManager.DoEvents'wait until all processes have finished
		'Dim Path As String = ThisDoc.PathAndFileName(False)'gets the path of the active document
		'Dim oDrawing As Inventor.DrawingDocument = ThisApplication.ActiveDocument'variable
		Sheet_Count = oDoc1.Sheets.Count 'variable - counts number of sheets in opened drawing
		Dim SheetNumber As Integer = 1'sets sheetnumber variable to equal 1 so below external rule is run starting on sheet 1 - passed through to "Batch - Update title block and border" rule
		For Each oSheet As Sheet In oDDoc.Sheets'iterates through every sheet in the open drawing
			Dim iLogicAuto = iLogicVb.Automation'sets up iLogic Automation
			Dim oArgs As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap'creates set of arguments to be passed to external rule
			oArgs.Add("SheetNumber", SheetNumber)'adds SheetNumber variable to argumetns to be passed through
			iLogicAuto.RunExternalRuleWithArguments(oDoc1, "Batch - Update title block and border", oArgs)'call for "Batch - Update title block and border" to be run from oDoc1 and passes through oArgs
			SheetNumber = SheetNumber + 1'increments SheetNumber by one to active next sheet in next loop
		'record that the changes were made
        oAppend.WriteLine(DateTime.Now.ToString("s") & DocName)
		oDoc1.Save2(False)'saves drawing
		oDoc1.Close(True)'closes drawing
		'nextfile :
		Catch
			oAppend.WriteLine(DateTime.Now.ToString("s") & DocName & "              < an error occured")
		oDoc1.Close(True)
	End Try
	Next'moves to the next file in filelist
	'close the writer when done
    close:
	oAppend.Close()
	MessageBox.Show("Done! " & FileList.Count & " files processed. " & vbCrLf & "See " & oFile & " for log", "Drawing update complete", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	'MessageBox.Show("Done!" & FileList.Count & " files were processed" & +vbCrLf+ & "See " & oFile " for log", "Rule complete", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	Exit Sub
'	errtrap:
'	Select Case Err.Number
'	Case Else
'		oAppend.WriteLine(DateTime.Now.ToString("s") & DocName & "              < an error occured")
'		oDoc1.Close(True)
'		Resume nextfile
'	End Select
End Sub
Batch - Update Title Block and Border
Sub Main()
	Dim SheetNumber As Integer = RuleArguments("SheetNumber")
	'MessageBox.Show(SheetNumber, "SheetNumber Value", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	Resize(SheetNumber)
	UpdateStyles()
	ChangeStyle()
	ChangeBorder()
	ChangeTitleBlock()
	AddOADimsTable(SheetNumber)
	AddRevTable()
End Sub
Sub Resize(SheetNumber)
	Dim oDrawing As DrawingDocument = ThisApplication.ActiveDocument 'variable
	'MessageBox.Show("1", "Debug", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	'MessageBox.Show("2", "Debug", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	'i = MessageBox.Show(Sheet_Size, "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	If Sheet_Size = "A2"'checks sheet size
		'i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In A2 branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		'i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In A3 branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	Else If Sheet_Size = "A4"
		'i = MessageBox.Show("Page resized!", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		'i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In A4 branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	Else
		'i = MessageBox.Show("Sheet size is " & Sheet_Size & vbCrLf & "In custom branch", "Page size", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		ActiveSheet.ChangeSize("A2", moveBorderItems := True) 'sets sheet to A2
End Sub
Sub UpdateStyles()
    OpenDoc = ThisDoc.Document
    oStyles = OpenDoc.StylesManager.Styles
    For Each oStyle As Style In oStyles
        If Not oStyle.UpToDate Then
            oStyle.UpdateFromGlobal
    Next
End Sub
Sub ChangeStyle()
	Dim oDrawingDoc As DrawingDocument = ThisDoc.Document
		'the styles collection
	Dim oStandardDesignStyles As DrawingStandardStylesEnumerator = oDrawingDoc.StylesManager.StandardStyles
	'find the right style and set it then exit
	Dim oStandardStyle As DrawingStandardStyle
	For Each oStandardStyle In oStandardDesignStyles
	    If oStandardStyle.Name = "Style Name here" Then
	        oDrawingDoc.StylesManager.ActiveStandardStyle = oStandardStyle
	        Exit Sub
	Next
End Sub
Sub ChangeBorder()
	ThisDrawing.ResourceFileName = "Full filepath of template drawing with Border.idw" 'document to copy title block and border from
	ActiveSheet.Border = "Border name here"'applies border to corresponding page size
End Sub
Sub ChangeTitleBlock()
	ThisDrawing.ResourceFileName = "Full filepath of template drawing with title blocks.idw" 'document to copy title block and border from
	ActiveSheet.SetTitleBlock("Title block name here", "PLACEHOLDER - CHANGE ME", "PLACEHOLDER - CHANGE ME")'applies title block that corresponds to page size
End Sub
Sub AddOADimsTable(SheetNumber)
	Sheet_Count = oDrawingDoc.Sheets.Count 'variable
	oSymbolDrawingName = "Sketch symbols.idw"
	'This is the name of the symbol to place
	oSymbolName = "OVERALL DIMENSION TABLE"
	Dim oSymbol As SketchedSymbol
	Sheet_Size = ActiveSheet.Size 'gets active sheet size
	Dim oPosition As Point2d
	'define the drawing document
	oDrawingDoc = ThisApplication.ActiveDocument
	Dim oSketchSymLib As SketchedSymbolDefinitionLibrary
	oSketchSymLib = oDrawingDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item(oSymbolDrawingName)
	Dim oSymDef As SketchedSymbolDefinition
	'place the symbol in the Drawing Resources folder
	oSymDef = oDrawingDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, oSymbolName, True)
			oPosition= ThisApplication.TransientGeometry.CreatePoint2d(45.65, 2.5)
			oSymbol = oDrawingDoc.ActiveSheet.SketchedSymbols.Add(oSymDef, oPosition, 0, 1, )
			oPosition= ThisApplication.TransientGeometry.CreatePoint2d(28.25, 2.5)
		Else
			'i = MessageBox.Show("Page size should be A2 or A3", "Incorrect page size!", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
End Sub
Sub AddRevTable()
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim Sheet_Size
	Dim X_Pos
	Dim Y_Pos
	Dim oRTBs As RevisionTables = oDrawDoc.ActiveSheet.RevisionTables
			X_Pos = 47.4
			Y_Pos = 41
			X_Pos = 30
			Y_Pos = 28.7
	Dim oLocation As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(X_Pos, Y_Pos)
	'add a new table
	Dim oRTB As RevisionTable
	oRTB = oRTBs.Add2(oLocation, True, True, False, "00")
End Sub
Message 16 of 17
Kassenbouw
I'm trying to use your code for running a rule on a folder but I don't know where to change the folder. It seems IO.DirectoryInfo is a link to Inventor2021\Bin\Folder. How do I change this?
Message 17 of 17
WCrihfield
Hi @Kassenbouw.  That object is not specific to any folder until you specify which folder it is to represent.  Basically, you would supply the path of the folder you want to work with within the () area.  Here is the official online documentation page for that Class:  (you may need to change the drop-down from C# to VB at the top of the page)
https://docs.microsoft.com/en-us/dotnet/api/system.io.directoryinfo?view=net-5.0
And here is the official online documentation page for the specific variation of the GetFiles method he used above.
https://docs.microsoft.com/en-us/dotnet/api/system.io.directoryinfo.getfiles?view=net-5.0#System_IO_...
These are not the only objects and methods that can be used for this (and similar) processes, but if they meet your specific needs, then that's all that matters.
Wesley Crihfield
