Create a new part with specific template
With this code Inventor create a new part with standart template.
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oPartDoc As PartDocument
Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, _
oApp.GetTemplateFile(kPartDocumentObject))
But i need to create a new part with specific template name "piece SHOP.ipt"
I don't find how.
Is someone can help me?
thank
JelteDeJong
try this:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim path As String
Set path = oApp.DesignProjectManager.ActiveDesignProject.TemplatesPath
Dim fullFileName As String
Set fullFileName = System.IO.Path.Combine(path, "piece SHOP.ipt")
Set oPartDoc = oApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, fullFileName)
Jelte de Jong
Blog: hjalte.nl - github.com
Thank for your help,
That doesn't work, there is a problem with "Path" said "Object required"
i don't find the solution.
Sub test()
Dim Path As String
Set Path = oApp.DesignProjectManager.ActiveDesignProject.TemplatesPath
Set fullFileName = System.IO.Path.Combine(Path, "piece SHOP.ipt")
End Sub
WCrihfield
Hi @Anonymous.  I assume you are trying to create a VBA macro with this code, right?
Well, the term 'ThisDoc' is not recognized in VBA, because it is defined within the iLogic add-in, for one thing, plus I don't think you even need to retrieve a currently open assembly document, if you are simply trying to create a new part file from its template.  Another point about VBA is that you don't need to use the 'Set' term in front of a line that is setting the value of a String (or a Double, Integer, or other simple data types), but you do for other types of variables.
Try this version.  I tested this on my own system (with a different file name) and it works for me.
Sub StartNewPieceShopPart()
    oTemplatesPath = oApp.DesignProjectManager.ActiveDesignProject.TemplatesPath
    oTemplateFile = "piece SHOP.ipt"
    oTemplate = oTemplatesPath & "\" & oTemplateFile
    Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, oTemplate)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Hi @WCrihfield ,
it's work.
thank you for this code and your explanations.
