I create a ClientGraphics of a planar parametric geometry structure made from straight lines and arcs using Inventor ClientGraphics API.
I would like create surfaces enclosed by the closed loops made from those lines and arcs, and then color them by assigning color each created surface.
How can i do it, using SurfaceGraphics for example, without going through creating solidsurfaces with Sketch methods or Part methods.
Below attached picture showing an example of planar geometry drawn with ClientGraphics.
Any help and idea is welcomed, thank you in advance.
HI!
I'm not sure about what you mean, but...
You have to create the surfaces using Extrude, Patch, Revolve, etc, depending the situation.
In this case, I believe Patch will be the tool to use.
After that, you can assign an appearance (color) to every surface.
Hi @CCarreiras,
Thank you for your suggestion.
But what i meant i want to create the surfaces or patches and color them without using Part Features like Extrude, Patch, Revolve, etc, or Sketch operations. I would like to do it only by using ClientGraphics and SurfaceGraphics if possible.
Taieb
Have a look at the following example, which I have taken from my blog. It creates a label like this.
In the function: "Label.New(doc As Document, name As String, point1 As Point, vector As UnitVector)" I create a red cone-shaped SurfaceBody (and text and a line) using ClientGraphics.
Public Class ThisRule
Sub Main()
Dim orign As Point = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
Dim direction As UnitVector = ThisApplication.TransientGeometry.CreateUnitVector(1, 0, 0)
Dim l1 As New Label(ThisDoc.Document, "www.hjalte.nl", orign, direction)
End Sub
End Class
Public Class Label
Private oClientGraphics As ClientGraphics
Private oDataSets As GraphicsDataSets
Private ThisApplication As Inventor.Application
Private name As String
Private orign As Point
Public Sub New(doc As Document, name As String, point1 As Point, vector As UnitVector)
Me.ThisApplication = doc.Parent
Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
Dim arrowLength As Double = 0.2
Dim arrowRadius As Double = 0.05
Dim labelLength As Double = 2
Me.name = name
Me.orign = point1
Dim point2 = oTg.CreatePoint(vector.X * labelLength + point1.X,
vector.Y * labelLength + point1.Y,
vector.Z * labelLength + point1.Z)
Dim point3 = oTg.CreatePoint(vector.X * arrowLength + point1.X,
vector.Y * arrowLength + point1.Y,
vector.Z * arrowLength + point1.Z)
Dim ClientGraphicsName = "hjalte.ClientGraphics-" & name
Dim GraphicsDataSet = "hjalte.GraphicsDataSet-" & name
Dim oCompDef As ComponentDefinition = doc.ComponentDefinition
Try
oClientGraphics = oCompDef.ClientGraphicsCollection.Add(ClientGraphicsName)
oDataSets = doc.GraphicsDataSetsCollection.Add(GraphicsDataSet)
Catch ex As Exception
oClientGraphics = oCompDef.ClientGraphicsCollection.Item(ClientGraphicsName)
oDataSets = doc.GraphicsDataSetsCollection.Item(GraphicsDataSet)
Return
End Try
' Create the cone!
Dim oSurfacesNode As GraphicsNode = oClientGraphics.AddNode(1)
Dim oTransientBRep As TransientBRep = ThisApplication.TransientBRep
Dim oBody As SurfaceBody = oTransientBRep.CreateSolidCylinderCone(point3, point1, arrowRadius, arrowRadius, 0)
Dim oSurfaceGraphics As SurfaceGraphics = oSurfacesNode.AddSurfaceGraphics(oBody)
oSurfaceGraphics.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
'Create text
Dim textGraphics As TextGraphics = oSurfacesNode.AddTextGraphics()
textGraphics.Text = name
textGraphics.Anchor = point2
textGraphics.HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextCenter
textGraphics.VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextMiddle
textGraphics.Bold = True
textGraphics.FontSize = 21
textGraphics.PutTextColor(0, 0, 255)
textGraphics.BurnThrough = True
textGraphics.DepthPriority = -10000000
'Create line
Dim LineGraphic As LineGraphics = oSurfacesNode.AddLineGraphics()
Dim oCoordSet As GraphicsCoordinateSet = oDataSets.CreateCoordinateSet(1)
oCoordSet.Add(1, point1)
oCoordSet.Add(2, point2)
LineGraphic.CoordinateSet = oCoordSet
Dim oGraphicsColorSet As GraphicsColorSet = oDataSets.CreateColorSet(1)
oGraphicsColorSet.Add(1, 0, 0, 0)
oGraphicsColorSet.Add(2, 0, 0, 0)
LineGraphic.ColorSet = oGraphicsColorSet
ThisApplication.ActiveView.Update()
End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
First i want to thank you for your great suggestion. It seems to me an interesting idea for me to try out. I'll try it and let you know if it works well for me. In the meantime, I have some concern about the performance in term of speed in the operation of creating SurfaceBody from TransientBrep solids that i have to create from the curves an the lines.
Taieb
