Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How can I color planar surfaces bounded by ClientGraphics Line and Arc entities?
4 REPLIES 4
bkhabeer
237 Views, 4 Replies
I create a ClientGraphics of a planar parametric geometry structure made from straight lines and arcs using Inventor ClientGraphics API.
I would like create surfaces enclosed by the closed loops made from those lines and arcs, and then MotorPreviewUsingClientGraphics.pngcolor them by assigning color each created surface.
How can i do it, using SurfaceGraphics for example, without going through creating solidsurfaces with Sketch methods or Part methods.
Below attached picture showing an example of planar geometry drawn with ClientGraphics.
Any help and idea is welcomed, thank you in advance.
4 REPLIES 4
CCarreiras
in reply to: bkhabeer
HI!
I'm not sure about what you mean, but...
You have to create the surfaces using Extrude, Patch, Revolve, etc, depending the situation.
In this case, I believe Patch will be the tool to use.
After that, you can assign an appearance (color) to every surface.
CCarreiras
bkhabeer
in reply to: CCarreiras
Hi @CCarreiras,
Thank you for your suggestion.
But what i meant i want to create the surfaces or patches and color them  without using Part Features like Extrude, Patch, Revolve, etc, or Sketch operations. I would like to do it only by using ClientGraphics and SurfaceGraphics if possible.
Taieb
JelteDeJong
Have a look at the following example, which I have taken from my blog. It creates a label like this.
In the function: "Label.New(doc As Document, name As String, point1 As Point, vector As UnitVector)" I create a red cone-shaped SurfaceBody (and text and a line) using ClientGraphics.
Public Class ThisRule
    Sub Main()
        Dim orign As Point = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
        Dim direction As UnitVector = ThisApplication.TransientGeometry.CreateUnitVector(1, 0, 0)
        Dim l1 As New Label(ThisDoc.Document, "www.hjalte.nl", orign, direction)
    End Sub
End Class
Public Class Label
    Private oClientGraphics As ClientGraphics
    Private oDataSets As GraphicsDataSets
    Private ThisApplication As Inventor.Application
    Private name As String
    Private orign As Point
    Public Sub New(doc As Document, name As String, point1 As Point, vector As UnitVector)
        Me.ThisApplication = doc.Parent
        Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
        Dim arrowLength As Double = 0.2
        Dim arrowRadius As Double = 0.05
        Dim labelLength As Double = 2
        Me.name = name
        Me.orign = point1
        Dim point2 = oTg.CreatePoint(vector.X * labelLength + point1.X,
                                    vector.Y * labelLength + point1.Y,
                                    vector.Z * labelLength + point1.Z)
        Dim point3 = oTg.CreatePoint(vector.X * arrowLength + point1.X,
                                    vector.Y * arrowLength + point1.Y,
                                    vector.Z * arrowLength + point1.Z)
        Dim ClientGraphicsName = "hjalte.ClientGraphics-" & name
        Dim GraphicsDataSet = "hjalte.GraphicsDataSet-" & name
        Dim oCompDef As ComponentDefinition = doc.ComponentDefinition
        Try
            oClientGraphics = oCompDef.ClientGraphicsCollection.Add(ClientGraphicsName)
            oDataSets = doc.GraphicsDataSetsCollection.Add(GraphicsDataSet)
        Catch ex As Exception
            oClientGraphics = oCompDef.ClientGraphicsCollection.Item(ClientGraphicsName)
            oDataSets = doc.GraphicsDataSetsCollection.Item(GraphicsDataSet)
            Return
        End Try
        ' Create the cone!
        Dim oSurfacesNode As GraphicsNode = oClientGraphics.AddNode(1)
        Dim oTransientBRep As TransientBRep = ThisApplication.TransientBRep
        Dim oBody As SurfaceBody = oTransientBRep.CreateSolidCylinderCone(point3, point1, arrowRadius, arrowRadius, 0)
        Dim oSurfaceGraphics As SurfaceGraphics = oSurfacesNode.AddSurfaceGraphics(oBody)
        oSurfaceGraphics.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
        'Create text
        Dim textGraphics As TextGraphics = oSurfacesNode.AddTextGraphics()
        textGraphics.Text = name
        textGraphics.Anchor = point2
        textGraphics.HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextCenter
        textGraphics.VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextMiddle
        textGraphics.Bold = True
        textGraphics.FontSize = 21
        textGraphics.PutTextColor(0, 0, 255)
        textGraphics.BurnThrough = True
        textGraphics.DepthPriority = -10000000
        'Create line
        Dim LineGraphic As LineGraphics = oSurfacesNode.AddLineGraphics()
        Dim oCoordSet As GraphicsCoordinateSet = oDataSets.CreateCoordinateSet(1)
        oCoordSet.Add(1, point1)
        oCoordSet.Add(2, point2)
        LineGraphic.CoordinateSet = oCoordSet
        Dim oGraphicsColorSet As GraphicsColorSet = oDataSets.CreateColorSet(1)
        oGraphicsColorSet.Add(1, 0, 0, 0)
        oGraphicsColorSet.Add(2, 0, 0, 0)
        LineGraphic.ColorSet = oGraphicsColorSet
        ThisApplication.ActiveView.Update()
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
bkhabeer
in reply to: JelteDeJong
@JelteDeJong,
First i want to thank you for your great suggestion. It seems to me an interesting idea for me to try out. I'll try it and let you know if it works well for me. In the meantime, I have some concern about the performance in term of speed in the operation of creating SurfaceBody from TransientBrep solids that i have to create from the curves an the lines.
Taieb
