How can I call a macro with arguments?
Hi
How can I pass arguments from iLogic to a vb macro?
I have tried the approach which we normally use when passing arguments between iLogic rules. But I am missing something in the process of passing the arguments to the VBmacro. Below is a simplified version of the problem. I want to control which sheet in the excel workbook opens...
Here is what I have:
iLogic code
Dim Value_1 As Integer
Value_1 = 1
Dim map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
map.Add("Arg", Value_1)
InventorVb.RunMacro("DocumentProject", "Access_excel", "openexcel", map)
Vb macro
Sub openexcel()
Dim oApp As Inventor.Application
Dim oOleRef As ReferencedOLEFileDescriptor
Dim oWB As Excel.Workbook
Dim oSheet As Excel.WorkSheet
Dim oChart As Excel.Chart
Set oApp = ThisApplication
Set oOleRef = oApp.ActiveDocument.ReferencedOLEFileDescriptors.Item(1)
Call oOleRef.Activate(kEditOpenOLEVerb, oWB)
Value_1 = RuleArguments("Arg")
If RuleArguments.Exists("Arg") Then
    Set oSheet = oWB.Sheets("Sheet1")
    oSheet.Activate
    MsgBox (oSheet.Name)
    Else
    Set oChart = oWB.Charts("Chart1")
    oChart.Activate
    MsgBox (oChart.Name)
End Sub
A workaround is to make two macros in VB and call them individually. But passing arguments to VB could also come in handy for other codes that we are working with.
MechMachineMan
I think by definition macros are intended to not be passed arguements, and to just be like a subroutine.
Try using external rules or internal rules instead, and having the rule ran by a macro so that you can make a button for it easily (if that is why you made it a macro in the first place).
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hi
It should be possible to pass arguments to a vb macro.
iLogic overview:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-BEBDED71-ED75-4329-ADBA-2E5DDCCF8DE8
Advanced techniques to write iLogic rules:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8DF6F761-1634-4D26-B13A-58AF275FD6F8
adam.nagy
Autodesk Support
Autodesk Support
I'm not sure which part of the linked online document you were referring to, but I did not find anything there that is about calling a VBA macro with parameters - only about calling Rules with parameters.
Also notice that there is no "RunMacro (with map)" in the function browser tree of iLogic:
What Justin said sounds correct to me.
Passing parameters to a VBA script has never been a built-in feature as they are supposed to run on their own.
Nevertheless, you can always store values somewhere in memory that is accessible to both VBA and iLogic, e.g. the clipboard.
You could even highjack the PostPrivateEvent/PeekPrivateEvent functions to pass a string to a macro:
iLogic code
Dim cmdMgr = ThisApplication.CommandManager
' Do this part from iLogic before calling the VBA macro
cmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kStringEvent, "Hello")
InventorVb.RunMacro("ApplicationProject", "Module1", "PostPeekEvent")
VBA Macro inside ApplicationProject >> Module1
Sub PostPeekEvent()
  Dim cmdMgr As CommandManager
  Set cmdMgr = ThisApplication.CommandManager
  Dim text As Variant
  Call cmdMgr.PeekPrivateEvent(kStringEvent, text)
  Call MsgBox(text)
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
Hi
Thanks for the answers.
Sorry I must have misread the help file on the chapter regarding "Rule arguments"
Adam
You show a nice workaround but I think that this is over my head 😉
I will stick to iLogic...
There was an other link were this was mentioned:
https://forums.autodesk.com/t5/inventor-general-discussion/ilogic/td-p/2611136
Regards
Kari
adam.nagy
Autodesk Support
Autodesk Support
Wow, you were right after all, Kari! 🙂
That makes things simpler:
http://adndevblog.typepad.com/manufacturing/2015/11/pass-parameters-to-a-vba-macro-from-an-ilogic-ru...
Adam Nagy
Hi
Yes it was even simpler than passing mapped values between iLogic rules...
The initial "simplified" rule above was solved as follows...
iLogic
MultiValue.SetList("d_macro_arg", "Chart1", "Sheet1")
' do the selection... Code
InventorVb.RunMacro("DocumentProject", "Access_excel", "openexcel", d_macro_arg, "Thanks Adam")
Vb macro
Sub openexcel(argument1 As String, argument2 As String)
If argument1 = "Sheet1" Then
    oSheet.Activate
    'MsgBox (oSheet.Name)
    Else
    oChart.Activate
    'MsgBox (oChart.Name)
MsgBox (argument2)
End Sub
Regards
Kari
