General Table Sheet Reference
Hello, Is it possible with a General Table, that is linked to Excel, to change which sheet if references with iLogic? If so could you point me in the right direction?
JBerns
@Anonymous,
Searching the forums I found this post:
https://forums.autodesk.com/t5/inventor-forum/ilogic-to-create-general-table-from-excel-file/td-p/7312196
This is related to iLogic and General Tables:
https://forums.autodesk.com/t5/inventor-forum/linking-properties-to-general-table-columns/td-p/7728891
I hope they are helpful.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
