Drawing Templates
Drawing Templates
Drawing Templates
You can set up a custom drawing template with views in it so that when you use the template with a part it automatically creates those views.  I'm trying to create one for our sheet metal parts, but I can't get it to create a flat pattern view and a folded view.  If anyone knows how to do this or could help figure it out that would be greatly appreciated.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
I think, same question is trying to address in your another post.
https://forums.autodesk.com/t5/inventor-customization/help-combining-macro-and-ilogic/m-p/8912685#M99678
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I'm trying multiple ways to accomplish this task.  If you add views to a drawing and then save it as a template when you create a new drawing using that template it asks you what part you want to use and it replaces the views with that part, but I can't get it to create flat patterns using that method.  On the other forum its using the replace model reference.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that VBA sample in below help documentation link may be helpful.
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-282E599E-8FC9-470A-9A4B-8E666E44E86B
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
