iLogic to create general table from excel file
ivan.liu
ivan.liu
I am new to iLogic programming and would like to simply replicate the action to insert a general table in an Inventor Drawing that is created from an excel file that i have previously made. The file table i have in excel already filled and formatted. I would like to do this because when i place a excel table object and link it, it does not update automatically when i update the drawing and if i add rows to the excel file table, the table in the drawing does not follow through.
Is there any chance someone can help me get started? I've seen many posts go the other way (exporting to excel) but all i need to do is just insert the general table.
MechMachineMan
The sample / programming help is your buddy here...
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-5EEA9BEE-3236-40D5-B3AA-840238C1E3AE
Directly from the Sample in the help:
*Note, this is coded in vba; thus must be used in the rule editor.
* conversion to vb.net for use in the rule environment simply involves removing get/set statements in this case.
Public Sub CreateDrawingExcelTable()
    ' Set a reference to the active drawing document
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Create the placement point for the table
    Dim oPoint As Point2d
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
    ' Create the table by specifying the source Excel file
    ' This assumes that the first row in the Excel sheet specifies the column headers
    ' You can specify a different row using the last argument of the AddExcelTable method
    Dim oExcelTable As CustomTable
    Set oExcelTable = oActiveSheet.CustomTables.AddExcelTable("C:\Temp\test.xls", oPoint, "Excel Table")
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Curtis_Waguespack
@ivan.liu wrote:
...I would like to do this because when i place a excel table object and link it, it does not update automatically when i update the drawing and if i add rows to the excel file table, the table in the drawing does not follow through.
Hi ivan.liu,
Let's make sure we understand the built in functionality first. See the information below. Does this do what you are wanting?
After placing a table that is linked to and Excel file, you should have a 3rd Party node in the browser. If you expand this and then right cliick on the Excel file link you should see Edit, which will open the file and allow you to change or add data.
Then you can right click on the table in the drawing and choose Update to see the results of the change.
(note that you do not need to edit the Excel file using the 3rd part node for the Update option to work. You can edit it using Excel as you normally would, and Inventor should detect the change and give you the Update option)
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
ivan.liu
Yes! Thanks MechMachineMan!
Just a few follow up questions:
1. How do I set the path of the excel file to be the Drawing File Name plus "_Barlist"?
2. How do I set the sheet to be a specific sheet?
3. How do i run this in macro iLogic so that it will be run before i save?
Thanks a lot!
ivan.liu
So I was able to answer my own questions and end up with the following:
Public Sub InsertQuantitiesTable()
'Set a reference to the active drawing document
'Find Drawing File Path without Extension
Dim Path As String
Path = ThisApplication.ActiveDocument.FullFileName
Path = Left(Path, Len(Path) - 4)
'Set a reference to the sheet
Set oActiveSheet = oDrawDoc.Sheets("SEGMENT DIMENSION I:2")
'Set the placement point for the table
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(24, 10)
'Create the table by specifying the source Excel file
'This assumes that the first row in the Excel sheet specifies the column headers
'You can specify a different row using the last argument of the AddExcelTable method
Set oExcelTable = oActiveSheet.CustomTables.AddExcelTable(Path & "_QUANTITIES.xlsx", oPoint, "ESTIMATED QUANTITIES PER SEGMENT")
End Sub
However, my table is not formatted as it is in excel. my first column needs to be widened. is there any way to add a input for the column width in the code above?
MechMachineMan
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-B8D1B7BF-6534-4E72-809C-7887FE8B9A09
Dim Path As String
'Use the integer of the column
oExcelTable.Columns(1).Width = 22
End Sub
Justin K
