flatpattern drawing
DWhiteley
flatpattern drawing
DWhiteley
Using the sample code below, how do I show the bend lines on the drawing view?
Thanks in advance, Dave
Public Sub AddFlatPatternDrawingView()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Create a new NameValueMap object
    Dim oBaseViewOptions As NameValueMap
    Set oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Set the options to use when creating the base view.
    Call oBaseViewOptions.Add("SheetMetalFoldedModel", False)
    ' Open the sheet metal document invisibly
    Dim oModel As Document
    Set oModel = ThisApplication.Documents.Open("C:\temp\SheetMetal.ipt", False)
    ' Create the placement point object.
    Dim oPoint As Point2d
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
    ' Create a base view.
    Dim oBaseView As DrawingView
    Set oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 1, _
    kDefaultViewOrientation, kHiddenLineRemovedDrawingViewStyle, _
    , , oBaseViewOptions)
End Sub
Replies (10)
adam.nagy
Autodesk Support
Autodesk Support
Hi Dave,
I think the best thing is always to try things in the UI and then examine the result in VBA Watches window:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
I assume you mean the "Bend Extents" option of the DrawingView. That only seems to be available when you place a Flat Pattern - you are placing a Folded Model:
If the option is available then it can be set using DrawingView.DisplayBendExtents
Cheers,
Adam Nagy
Autodesk Platform Services
o.sassen
I would like to place a base view of folded model.
Call oBaseViewOptions.Add("SheetMetalFoldedModel", True)
I have tried this, but with no succes.
Can anybody tel me how to create the folded model, isometric view.
Thank you!
MechMachineMan
1. This is an old post. Please make a new post instead of reviving old threads.
2. What isn't working about it? Where is the full section of code to see what you are doing wrong? That single line you typed looks just fine. How it's used in the larger program may be a different story.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @o.sassen,
I tried the following sample VBA code with attached part. Before running this code, make sure that a drawing document is opened in Inventor 2018.
    Dim oSheet As Sheet
    Set oModel = ThisApplication.Documents.Open("Path of file\Mounting Bracket.ipt", False)
End Sub
In the above code, path of file need to update after downloading attached part.
SheetMetalFoldedModel_FalseSheetMetalFoldedModel_FalseSheetMetalFoldedModel_TrueSheetMetalFoldedModel_True
Please feel free to contact if there is any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
o.sassen
Yes it's is working, but I don't understand why. What dit you change? The only difference is the true or false statement. But when I change this in my code it's not working.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @o.sassen,
Can you please share your code to test?
please make sure that files and data are non confidential one.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
o.sassen
This is what I tried:
Dim oSheet As Sheet
' Create a new NameValueMap obja jject
Run-time error '5':
"Invallid procedure call or argument"
Set oModel = ThisApplication.Documents.Open("C:\Vault\Designs\Klimaat\Projecten\Norby\CO2 Collector\part1.ipt", False)
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(6, 20)
Set oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 1 / 25, kIsoTopRightViewOrientation, kShadedDrawingViewStyle, _
' Set oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 1 / 25, _
' kFlatBacksidePivotLeftViewOrientation, kHiddenLineRemovedDrawingViewStyle, _
' , , oBaseViewOptions)
End Sub
o.sassen
Oh sorry all, I already know what was wrong. I was using a wrong view.
Case closed. It's is working perfectly now!
dgreatice
maybe like this?:
    Dim oSheet As Sheet
   Dim oDwgCurve As DrawingCurve
   For Each oDwgCurve In oBaseView.DrawingCurves
         If oDwgCurve.EdgeType = kBendDownEdge Then
            oDwgCurve.Segments.Item(1).Visible = False
        End If
   Next
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @o.sassen,
Nice to hear that your code is also wokring!!!
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
