Find Object Type of Transient Geometry Objects
2 REPLIES 2
509 Views, 2 Replies
I have an ObjectCollection object that contains a bunch of transient geometry (mostly Cirle2d's and LineSegment2d's).  I'm looping through it and performing operations on each object.  There are some operations that are different depending on whether the object is a circle or a line.  Is there a way to check which type of 2d geometry the object is?  Most objects have a "Type" property, but these don't, which is very frustrating.
2 REPLIES 2
LukeDavenport
LukeDavenport
Hi Odeyoe,
I think you can do this (although I haven't tested it). Does that work?
Luke
For Each O In OBJ
      Dim testType As String = TypeName(O)
      Select Case testType
             Case "LineSegment2d"
                    MsgBox("Line Segment")
             Case "Circle2d"
                    MsgBox("Circle")
       End Select
Next
Hi Odeyoe,
Luke
For Each O In OBJ
             Case "Circle2d"
                    MsgBox("Circle")
       End Select
Next
in reply to: LukeDavenport
This appears to be working.  Thank you!
