export two part lists table to excel on two tabs using template
GosponZ
Message 1 of 19
GosponZ
I'm looking for ilogic code to export 2 parts list tables into excel and to be exported on two tabs in excel.
Thanks for any help
Replies (18)
Message 2 of 19
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi MisterZS,
Please find a sample code in the following. Which exports BOM to 2 excels of "Structured" BOMviews and "Parts Only" BOMViews. Then copies one excel data to another excel. The code can be modified as per requirement.
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    ' Set the structured view to 'all levels'
    oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    ' Set a reference to the "Structured" BOMView
    Dim oStructuredBOMView As BOMView
    oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    ' Export the BOM view to an Excel file
    oStructuredBOMView.Export("C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat)
	' Make sure that the parts only view is enabled.
    oBOM.PartsOnlyViewEnabled = True
    ' Set a reference to the "Parts Only" BOMView
    Dim oPartsOnlyBOMView As BOMView
    oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
    oPartsOnlyBOMView.Export("C:\temp\BOM-PartsOnly.xls", kMicrosoftExcelFormat)
	GoExcel.Open("C:\temp\BOM-PartsOnly.xls")
	wb = GoExcel.Application.ActiveWorkbook
	ws = wb.WorkSheets.Add()
	GoExcel.Save()
	GoExcel.Close()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "A1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "A1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "B1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "B1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "C1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "C1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "D1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "D1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "E1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "E1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "F1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "F1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "G1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "G1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "H1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "H1", "")
	GoExcel.Save()
	GoExcel.CellValues("C:\temp\BOM-PartsOnly.xls", "Sheet2", "I1", "") = GoExcel.CellValues("C:\temp\BOM-StructuredAllLevels.xls", "Sheet1", "I1", "")
	GoExcel.Save()
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 19
GosponZ
Thank you for your answer and sample code. I need to be in dwg and to  have 2 custom parts list table. I need export  2 tables from drawing in excel but on 2 tabs.
Thanks again
Message 4 of 19
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi MisterZS,
Please try the sample code to export PartsList into a excel in 2 tabs for Drawing document.
 	Dim oDOc As DrawingDocument
    	oDOc = ThisApplication.ActiveDocument
	Dim oSheet As Sheet
 	oSheet = oDOc.Sheets.Item(1)
	Dim oPartList As PartsList
 	oPartList = oSheet.PartsLists.Item(1)
	Call oPartList.Export("C:\Temp\1.xls", PartsListFileFormatEnum.kMicrosoftExcel)
	Dim oPartList1 As PartsList
 	oPartList1 = oSheet.PartsLists.Item(2)
	Call oPartList1.Export("C:\Temp\1.xls", PartsListFileFormatEnum.kMicrosoftExcel)
Please feel free to contact if there is any doubt.
If solves your question, please "Accept as Solution" / give a kudo.
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 19
GosponZ
Hi Chandra,
this codes working perfect, but before close this case can you tell me if you can add codes to pull excel template first and then export as it is.
Thank you
Message 6 of 19
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi MisterZS,
Please find the following sample code with excel template path.
	Dim oSheet As Sheet
	Dim oOptions As NameValueMap
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oOptions.Value("Template") = "C:\Temp\2.xls"
	Call oPartList.Export("C:\Temp\3.xls", PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
        Call oPartList1.Export("C:\Temp\3.xls", PartsListFileFormatEnum.kMicrosoftExcel)
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 19
GosponZ
Hi Chandra,
it looks like it does partial good job. It overwrite template. I need template to be clean and reusable and if possible to save file as current dwg file
Thanks again
Message 8 of 19
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi MisterZS,
Please find the sample code to export partlist to excel and save file as current dwg file.
	Dim oSheet As Sheet
	oOptions.Value("Template") = "C:\Temp\Template.xls"
	Dim name As String = oDOc.DisplayName.Replace(".idw", "")
	Call oPartList.Export("C:\Temp\" & name & ".xls", PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
    Call oPartList1.Export("C:\Temp\" & name & ".xls", PartsListFileFormatEnum.kMicrosoftExcel)
 Pleas find the attached template file also.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 19
GosponZ
Perfect.
Thanks a lot
Message 10 of 19
Hi Guys,
I have a similar problem I need to solve. I'd like to export the BOM (parts only view) to existing Excell file template. I would like to keep the original
cells format of this template and fill only specified range of cells. I'm using custom iProperities vaule and custom BOM table configuration. I'm able to export it through a simple iLogic rule to the Excell file also. But the problem is how to export the BOM to specified range of cells in the exisitng Excell template.
Thanks in advance for help
Tomek
Message 11 of 19
MechMachineMan
Tom, you cannot export the BOM easily to a certain range of cells and keep the formatting.
Exporting BOM (from assembly) overrwrites the excel file and creates a brand new one.
PartsList exporting (from Drawings) allows you to use a template, which is what you need to try, and is what is shown in the solution code.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 12 of 19
Hi, Thanks for reply,
Where I can find this solution code, You have mantioned about?
Message 13 of 19
MechMachineMan
The code contained within the highlighted green post in this thread, that Chandra had posted.... ?
Justin K
Message 14 of 19
I've found some solution how to solve the problem directly from an assembly. But I don't know how to get number of parts for each position in the BOM.
Is there some iLogic function whitch allows to do this?
Message 15 of 19
MechMachineMan
What do you mean "number of parts for each position" in the BOM?
Are you talking about having different position reps???
Are you unfamiliar with Parts Only parts list, and that's what you are talking about?
We are not mind readers here...
Justin K
Message 16 of 19
GosponZ
I'm wandering if is somehow possible to insert in excel template file name cell A1 and value that will be read from iprop in cell B1.
Eng in cell A2 and value in B2 etc..and that to be only on first sheet or first tab in excel before code above from Mr. Chandra.
Thank you
Message 17 of 19
chandra.shekar.g
Autodesk Support
Autodesk Support
@GosponZ,
I am not clear about requirement. Can you please provide some screen shots to explain?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 18 of 19
GosponZ
I would like to use code from above, but need some upgrade on code.
First sheet in Excel to looks like this picture.
iProperties to fill empty cell.
2 tables would be exported into 2 tabs in excel same as accepted code above.
Message 19 of 19
MechMachineMan
Here is a sample that should get you started. Note that I have partially encapsulated it; tweaking the section that Chandra originally wrote so it's more "reusable". I left the rest without so it would be easier for you to add iProps/cells.
Best way to find more about what you can do with the excel commands is to google "msdn + excel + vba + [your question here]".
Sample result: https://msdn.microsoft.com/en-us/vba/excel-vba/articles/xlhalign-enumeration-excel
Can add remove iProps/cells/static data/new rows using the same format/pattern as outlined in the section.
*You may need to tweak sheet name to make the excel portion work properly
Sub Main()
Dim oDwgDoc As DrawingDocument
oDwgDoc = ThisDoc.Document
Dim exceloutputname as String
exceloutputname = "C:\Temp\" & oDOc.DisplayName.Replace(".idw", "") & ".xlsx"
Call ExportSheetPartsLists(oDwgDoc.Sheets.Item(1), oOutputExcelName)
Dim xlApp As Object
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlwb = xlApp.Workbooks.Open(oOutputExcelName
xlws = xlwb.Worksheets("Sheet1")
xlws.Range("A1").EntireRow.Insert
xlws.Range("B1") = "Product #:"
xlws.Range("B1").Font.Bold = True
xlws.Range("B1").HorizontalAlignment = -4152
xlws.Range("B2") = iProperties.Value("Project", "Part Number")
xlws.Range("D1") = "Description:"
xlws.Range("E1") = iProperties.Value("Project", "Description")
xlws.Range("H1") = "Customer"
xlwb.Save
'xlwb.Close
'xlApp.Quit
xlws = Nothing
xlwb = Nothing
xlApp = Nothing
End Sub
Sub ExportSheetPartsLists(oSheet As Sheet, OutputName as String)
For Each oPartsList in oSheet.PartsLists
If oFirstPL = True Then
Call oPartList.Export(OutputName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
oFirstPL = False
Else
Call oPartList1.Export(OutputName, PartsListFileFormatEnum.kMicrosoftExcel)
End if
Next
End Sub
Justin K
