Export Parts List to Excel [VBA]
JoãoASilva
JoãoASilva
Hello!
I stumbled upon a VBA code to export a parts list to excel, using the iLogic Interop.excel reference.
The code is really good, and I adjusted it to my needs, but there is one thing I can't figure out how to change.
I need to export the parts list as it is, but not including the first column.
I should include that the macro uses a company template.
My parts list in the drawing:
My parts list on the drawing.My parts list on the drawing.
Outcome of the macro:
Result of the current macro.Result of the current macro.
What i want from the macro:
What i want from the macro.What i want from the macro.
This is my code:
AddReference "Microsoft.Office.Interop.Excel"
Dim oExcel As New Microsoft.Office.Interop.Excel.Application
' For debugging
'oExcel.Visible = True
'get PDF target folder path
ooFolder = ThisDoc.PathAndFileName
'get drawing name
oName = ThisDoc.FileName
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(ooFolder) Then
    System.IO.Directory.CreateDirectory(ooFolder)
Dim oWB As Object
oWB = oExcel.Workbooks.Open("Z:\MecanicaDoc\MEC_PROJ\Requisição Interna XXXxx.xxxx.xlsm")
Dim oWS As Object
oWS = oWB.ActiveSheet
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
' Export the first PartsList
Dim oPL As PartsList
oPL = oSheet.PartsLists(1)
' Starting cell position on the Excel sheet
Dim iRowStart As Integer: iRowStart = 9
Dim iColStart As Integer: iColStart = 1
' Export headers
Dim iRow As Integer: iRow = iRowStart
Dim iCol As Integer: iCol = iColStart
Dim oCol As PartsListColumn
For Each oCol In oPL.PartsListColumns
  oWS.Cells(iRow, iCol).Value = oCol.Title
  iCol = iCol + 1
Next
iRow = iRow + 1
' Export content
Dim oRow As PartsListRow
For Each oRow In oPL.PartsListRows
  iCol = iColStart
  Dim oCell As PartsListCell
  For Each oCell In oRow
    oWS.Cells(iRow, iCol).Value = oCell.Value
    iCol = iCol + 1
  Next
  iRow = iRow + 1
Next
'For Each oCell In oPL.PartsListColumns
'	oWS.Cells(iRow, iCol).Value = ""
'	iRow = iRow + 1
'Next
' Save it
' We disable the confirmation dialog
' in case the file already exists and
' needs to be overwritten
oExcel.DisplayAlerts = False
Call oWB.SaveAs(ooFolder & "\" & oName & ".xlsm")
' Close excel
Call oExcel.Quit
Thanks in advance!
João Silva
Mechanical Engineer
bradeneuropeArthur
This could be an option:
 If OInvdrawdoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            Dim oSheet As Inventor.Sheet
            oSheet = OInvdrawdoc.Sheets.Item(1)
            Dim strFileNameNoExt As String = System.IO.Path.GetFileNameWithoutExtension(OInvdrawdoc.FullFileName)
            Dim opl As PartsList
            If oDrawSheet.PartsLists.Count = 0 Then
                Exit Sub
            opl = oDrawSheet.PartsLists.Item(1)
            Dim oOptions As NameValueMap
            oOptions = AppInventor.TransientObjects.CreateNameValueMap
            oOptions.Value("StartingCell") = "a1"
            oOptions.Value("ExportedColumns") = "QTY;UNID;DESCRIPTION;VENDOR;PART NUMBER;FABRICANTE"
            oOptions.Value("Template") = "Template file location"
            oOptions.Value("ApplyCellFormatting") = True
            oOptions.Value("ForceCellToText") = False
            oXlsExportFilePath = WriteToDirectoryNamePartlist & "\_Xls\" & strFileNameNoExt & " (PART-LIST).xls"
            Dim Informatie As FileInfo
            Informatie = New FileInfo(oXlsExportFilePath)
            If System.IO.File.Exists(oXlsExportFilePath) Then
                Informatie.IsReadOnly = False
                Kill(oXlsExportFilePath)
                opl.Export(oXlsExportFilePath, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
            Else
End if
        Exit Sub
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JoãoASilva
I had a piece of code similar to that one, but it stopped working, so I had to find another way.
The code I provided works almost perfectly, but to make it work exactly like I want, probably needs a lot of changes.
What did you define "FileInfo" as?
João Silva
Mechanical Engineer
bradeneuropeArthur
System.IO.fileinfo
Dim Informatie As System.IO.FileInfo
            Informatie = New System.IO.FileInfo(oXlsExportFilePath)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
JoãoASilva
Unfortunately, no sucess!
Same error as before:
"O parâmetro está incorreto" > "The parameter is incorrect"
That's the reason I'm triyng to switch to VBA, to see if I can achieve the same results I had before.
João Silva
Mechanical Engineer
Your code is working smooth and perfect. I took my template and save as xlsm in temp folder just for testing. I tried with couple parts list and working with all of them same. Without parts list in drawing will be error. Thank you
