Export of DXF assembly thickness in decimetres.
2 REPLIES 2
J.J.Kucharczyk
157 Views, 2 Replies
I have searched the forum. I have not found an answer, so I apologise in advance if I duplicate.
I have an assembly, when automatically exporting to DXF files for some thicknesses it gives the result x.xxxxxxxxxxxxx instead of x.xx. The same part from the IPT file when exported with iLogic shows the correct value of x.xx .
We did not have problems with inventor 2024.
I have included the code I use below.
Thanks in advance for all sugestions.
Private Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oBOMView As BOMView = GetBOMpartsOnly(oDef.BOM)
	For Each oRow As BOMRow In oBOMView.BOMRows
		Dim oRowDef As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
		Dim partDoc As PartDocument = oRowDef.Document
		If partDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Dim oCompDef As SheetMetalComponentDefinition = oRow.ComponentDefinitions.Item(1)
			Dim oDataIO As DataIO = oDoc.ComponentDefinition.DataIO
			If oCompDef.HasFlatPattern=False Then
				oCompDef.Unfold
			Else
			'	oCompDef.FlatPattern.Edit
			End If
			Dim sOut As String = "FLAT PATTERN DWG?AcadVersion=2000" _
			+"&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL;IV_FEATURE_PROFILES_DOWN" _
			+"&SimplifySplines=True" _
			+"&LINEAR TOLERANCE=0.010" _
			+"&MergeProfilesIntoPolyline=True" _
			+"&RebaseGeometry=False" _
			+"&TrimCenterlines=True"
			Dim invPropSets As PropertySets = partDoc.PropertySets
			Dim invPropSet As PropertySet = invPropSets.Item("Design Tracking Properties")
			Dim invPartNumiProp As Inventor.Property = invPropSet.Item("Part Number")
			Dim dThick As Double = oCompDef.Thickness.Value
			Dim iQ As Integer = oRow.TotalQuantity
			Dim sName As String = partDoc.DisplayName
			Dim sMaterial As String = partDoc.ActiveMaterial.DisplayName
			Dim FlatExtentsLength As String = oCompDef.FlatPattern.Length.ToString("0.00") * 10
			Dim FlatExtensWidth As String = oCompDef.FlatPattern.Width.ToString("0.00") * 10
			Dim sFname As String = ThisDoc.Path & "\" & dThick * 10  & "mm" & "-" & iQ & "stk" & "-  -" & sName & " - "  & FlatExtentsLength &"x" & FlatExtensWidth & "mm" & " - "  & sMaterial &".dxf"
			oCompDef.DataIO.WriteDataToFile(sOut,sFname)
			oCompDef.FlatPattern.ExitEdit
			If partDoc.ComponentDefinition.IsiPartFactory Or
				partDoc.ComponentDefinition.IsiPartMember Then
				partDoc.Save()
			End If
		End If
	Next
End Sub
Private Function GetBOMpartsOnly(ByVal oBOM As BOM) As BOMView
	Dim oLanguageBOM As String
	Select Case ThisApplication.LanguageCode
	Case "en-US"
		oLanguageBOM = "Parts Only"
	Case Else
		Exit Function
	End Select
	If oBOM.PartsOnlyViewEnabled = False Then
		oBOM.PartsOnlyViewEnabled = True
	End If
	Return oBOM.BOMViews.Item(oLanguageBOM)
End Function
2 REPLIES 2
Hi, replace in line 37     dThick * 10    with     Math.Round(dThick * 10, 2)
Works like a dream 🙂 Huge thank you!
