Inventor 2017 using Visual Studio 2019 and C#.
Referring to a .DWG drawing file.
I have an Add-In I created years ago, that I would like to add some functionality to.
I would like to be able to detect whether an image file is embedded within a drawing sheet.
If one already exists I would like to determine the insertion point and scale of said image.
I would also like to be able to replace said image, or insert one if image not present. The image is a bitmap or jpeg.
This image is directly inserted into a drawing sheet, not part of a sketch or part of a titleblock.
Any ideas? Solution does not have to be in C# but preferred if possible.
Thanks in advance.
