- Mute
- Permalink
- Report
When trying to add a DrawingNote object, I've encountered some strange behaviour related to the positioning (Point2D) of it. At least that's what I think, but maybe there's some logic behind it? Does anyone have an explaination? Or is it a bug?
See code below, where the last line of code does position the text how I want it, but when commented out places it differently. I have not changed the Point2d as you can see, I've just set the GeneralNote position to the same Point2d as I did when initially placing it.
private void insertSheetNote(Sheet sheet) { TransientGeometry transientGeometry = InventorApp.TransientGeometry; GeneralNotes generalNotes = sheet.DrawingNotes.GeneralNotes; string noteText = "NOTE: This is \n" + "my multiline \n" + "test text."; double textPositionY = sheet.Border.RangeBox.MaxPoint.Y - 0.35 - 1; double textPositionX = sheet.Border.RangeBox.MinPoint.X + 0.35 + 2; Point2d textPosition = transientGeometry.CreatePoint2d(textPositionX, textPositionY); GeneralNote generalNote = generalNotes.AddFitted(textPosition, noteText); generalNote.TextStyle.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft; //generalNote.Position = textPosition; }
This picture shows the note with the last line of code commented out:
This picture shows the note whit the last line of code active:
Anyone knows what's happening, or if it's a bug or something?
