DrawingNote position (Point2d) behaviour.
catot
catot
When trying to add a DrawingNote object, I've encountered some strange behaviour related to the positioning (Point2D) of it. At least that's what I think, but maybe there's some logic behind it? Does anyone have an explaination? Or is it a bug?
See code below, where the last line of code does position the text how I want it, but when commented out places it differently. I have not changed the Point2d as you can see, I've just set the GeneralNote position to the same Point2d as I did when initially placing it.
        private void insertSheetNote(Sheet sheet)
            TransientGeometry transientGeometry = InventorApp.TransientGeometry;
            GeneralNotes generalNotes = sheet.DrawingNotes.GeneralNotes;
            string noteText = "NOTE: This is \n" +
                "my multiline \n" +
                "test text.";
            double textPositionY = sheet.Border.RangeBox.MaxPoint.Y - 0.35 - 1;
            double textPositionX = sheet.Border.RangeBox.MinPoint.X + 0.35 + 2;
            Point2d textPosition = transientGeometry.CreatePoint2d(textPositionX, textPositionY);
            GeneralNote generalNote = generalNotes.AddFitted(textPosition, noteText);
            generalNote.TextStyle.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft;
            //generalNote.Position = textPosition;
This picture shows the note with the last line of code commented out:
This picture shows the note whit the last line of code active:
Anyone knows what's happening, or if it's a bug or something?
bshbsh
you have not, but the insertion point of the note have changed when you changed the horizontal justification. it was probably horizontally centered before.
generalnotes.addfitted
catot
Yes, that seems to explain it, thanks.
