Can some body help me out with the positioning of title block in the drawing sheet having dual borders.
The default setting will insert the title block on the bottom most line of drawing border.
I am expecting it to be placed at the corner as shown below.
Solved by JelteDeJong. Go to Solution.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet = oDrawDoc.ActiveSheet If Not oSheet.TitleBlock Is Nothing Then oSheet.TitleBlock.Delete Dim oTitleBlockDef As TitleBlockDefinition = oDrawDoc.TitleBlockDefinitions.Item("ISO") Dim oTitleBlock As TitleBlock = oSheet.AddTitleBlock(oTitleBlockDef)
Hi, This is a simple example of ilogic, which places a titleblock on a sheet. In this example, the titleblock should not have text entries.
Please, if possible, attach your file here to analyze it.
Regards!
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
hi,
in the titleblock definition add an Point and turn it into a "Connection Point Grip". Set the dimensions the same as the width of your border.
Jelte de Jong
Blog: hjalte.nl - github.com
