Define A-Side from Assembly
evan.wondra
Message 1 of 8
evan.wondra
I am wanting to create some iLogic that will be run from an assembly file, and it will look at each part and see if A-Side has been defined. If it has not been defined, it will delete the flat pattern (if one exists) and then pause and allow users to define A-Side. The portion of the code I am having issues with is below. If I run that from an individual part file, it works. However when I run a different rule from an assembly file that opens up all parts and then runs this rule, it does not work. It acts the same, but it does not actually define the A-Side.
Any help on this is much appreciated.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.ASideFaceStatus.ToString <> "kASideUpToDate" Then
	MessageBox.Show("MUST DEFINE A-SIDE " & iProperties.Value("Project", "Part Number"), "DEFINE A-SIDE", MessageBoxButtons.OKCancel, MessageBoxIcon.Stop)
	'Delete Flat Pattern if no A-Side
		iLogicVb.RunExternalRule("DELETE FLAT PATTERNS")
	'Start Define A-Side Command
			Dim face As Inventor.Face
		face = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Define A-Side")
		Call ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalCreateASideCmd").Execute
Replies (7)
Message 2 of 8
dalton98
Add this. Also on your first if statement you would need to change it to 'If Not'
Dim oAss As AssemblyDocument
oAss = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
'all parts in assembly For Each oOcc In oAss.ComponentDefinition.Occurrences.AllLeafOccurrences
If Not oOcc.Definition.ASideDefinitions.Count = 0 Then Continue For
Dim oDoc As PartDocument oDoc = ThisApplication.Documents.Open(oOcc.Definition.Document.FullFileName, True)
'your code
oDoc.Save
oDoc.Close
Next
Message 3 of 8
evan.wondra
Thanks  for the quick response! That additional code allows me to run it from an assembly file, however it is still not keeping the selected side as my A-Side. I attached an image of the part and the model tree. It opened up the part and allowed me to select a face, but it does not keep that selection to be used as my defined A-Side
Message 4 of 8
dalton98
try selecting the face after picking it, then clearing the select after you define the a-side.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
oDoc.SelectSet.Select(face)
oDoc.SelectSet.Clear
 Edit: I was wrong you dont need to change the if statement(not used to that notation). You could put them all under one if statement adding the extra 'If oCompDef.Aside...' isnt nessessary
Message 5 of 8
dalton98
I change the my first post so it checks if an A-side exists before it tries to open the part
Message 6 of 8
evan.wondra
Yes, that worked!! Thank you for all your help
Message 7 of 8
cadEY2BL
@evan.wondra
Could you post your complete code?
Message 8 of 8
evan.wondra
Yes, I had to split it into two different rules so I will post both below.
If ThisApplication.ActiveDocumentType = "12290" Then
		MessageBox.Show("MUST DEFINE A-SIDE " & iProperties.Value("Project", "Part Number"), "DEFINE A-SIDE", MessageBoxButtons.OK, MessageBoxIcon.Stop)
		ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalCreateASideCmd").Execute2(True)
		oDoc.ComponentDefinition.Unfold
		oDoc.ComponentDefinition.FlatPattern.ExitEdit
' Check the document type
If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	' Define the active assembly
	Dim oAssyDoc As AssemblyDocument
	oAssyDoc = ThisApplication.ActiveDocument
	' Check all referenced docs
	For Each oDoc As Document In oAssyDoc.AllReferencedDocuments
		' Check if the part is sheet metal
		If oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			' Get sheet metal component definition
			Dim oSMCD As Inventor.SheetMetalComponentDefinition
			oSMCD = oDoc.ComponentDefinition
			' Check If it has flatpattern
			If oSMCD.HasFlatPattern = True Then
				' Atempt to delete it
				Try
					oSMCD.FlatPattern.Delete
				Catch
				End Try
	Next
ElseIf ThisApplication.ActiveDocument.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
	' Get the sheetmetal component definition
	oSMCD = ThisApplication.ActiveDocument.ComponentDefinition
		Try
		Catch
		End Try
' Update the files
InventorVb.DocumentUpdate()
