Choosing document type using Python and the API
nj21997
nj21997
I'm having difficulty importing an assembly file into python. There seems to be a conflict between the result when I use Document.Type and Document.DocumentType. The second recognises that the file is an an assembly. But the first returns the ObjectType which is what I need so that I can manipulate the assembly.
Does anyone know how I can force the object type to change?
arron.craig
You will probably have better luck posting in the Inventor API forum here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/bd-p/120
nj21997
Cheers!
Michael.Navara
Please provide some code snippet and be more specific, because I don't understand what do you want to do.
Both values Document.Type and Document.DocumentType can't be changed in any way because it is read only.
