ilogic project center point into Sketch
dimamazutaMMJ32
dimamazutaMMJ32
Hello.
When I copy sketch from one part to another the center point is not created in the new sketch. Is there a way to project a center point into a sketch using ilogic?
Thank you for your help.
JelteDeJong
is this what you are looking for
Dim sketch As PlanarSketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "")
Dim partDef As PartComponentDefinition = sketch.Parent
Dim cp = partDef.WorkPoints.Item("Center Point")
sketch.AddByProjectingEntity(cp)
Jelte de Jong
Blog: hjalte.nl - github.com
dalton98
It automatically projects the origin point if you manually start a new sketch so im assuming your creating the sketch with ilogic aswell?
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = oDoc.ComponentDefinition.Sketches.Add(oCompDef.WorkPlanes.Item("XY Plane"))
'add origin point
oSketch.AddByProjectingEntity(oCompDef.WorkPoints.Item("Center Point"))
oSketch.Edit
Dim oPasteControlDef As ControlDefinition
oPasteControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
oPasteControlDef.Execute
oSketch.ExitEdit
dimamazutaMMJ32
Yes, I create sketch with ilogic.
Thanks for your help!
