Select Case Syntax
Select Case Syntax
brad.jackson
Select Case Syntax
brad.jackson
I am trying to set a part number in iProperties based on the cut length of the part.  We get this raw part in four different lengths and I need to set the part number according to the 'Track_Length' user parameter in the part.  I am getting errors when I hit a line that uses the 'And' operator.  I am using this method to define what to do if the value is between two values.
Any help would be greatly appreciated.
'5598 = 11'-0"
'1557 = 13'-0"
'1558 = 17'-0"
'1559 = 21'-0"
'Set track part number in iProperties based on part length.
Select Case TRACK_LENGTH
Case TRACK_LENGTH <= 132
iProperties.Value("Project", "Part Number") = "5598"
Case TRACK_LENGTH > 132 And <= 156
iProperties.Value("Project", "Part Number") = "1557"
'Case TRACK_LENGTH > 156 And <= 204
'iProperties.Value("Project", "Part Number") = "1558"
'Case TRACK_LENGTH > 204 And <= 252
End Select
JelteDeJong
you can try it like this
Dim inch11 = 11 * 25.4 '5598 = 11'-0"
Dim inch13 = 13 * 25.4 '1557 = 13'-0"
Dim inch17 = 17 * 25.4 '1558 = 17'-0"
Dim inch21 = 21 * 25.4 '1559 = 21'-0"
Select Case True
    Case TRACK_LENGTH <= inch11
    Case inch11 < TRACK_LENGTH And TRACK_LENGTH <= inch13
    Case inch13 < TRACK_LENGTH And TRACK_LENGTH <= inch17
    Case inch17 < TRACK_LENGTH And TRACK_LENGTH <= inch21
End Select
Jelte de Jong
Blog: hjalte.nl - github.com
brad.jackson
Thanks for the help.  What I actually noticed from your example was that I did not have my variable before the second argument on lines {9, 11, and 13}.  Once I added them it worked like a charm.
Select Case True
	Case TRACK_LENGTH <= "132"
	Case TRACK_LENGTH > "132" And TRACK_LENGTH <= "156"
	Case TRACK_LENGTH > 156 And TRACK_LENGTH <= 204
	Case TRACK_LENGTH > 204 And TRACK_LENGTH <= 252
		iProperties.Value("Project", "Part Number") = "1559"
End Select
