Hi everyone,
How to create a common parameter database that can be accessed by all the inventor files through ilogic or somehow?
For example, creating a dimension parameters database and accessing those parameters through the code in an application.
Kindly help me on this query.
Khizam
What's the difference between accessing parameter through a database ((filename, model state name, parameter name) would be the key, I think) and through inventor document object? What's your pourpose?
Anyway you could leverage ModelingEvents.OnNewParameter / OnParameterChange to store the parameters in your database.
And for such a simple database I would recommend SQLite, but internet is a better place to look for this answer.
I will explain the use case,
say for example, I have a dimension parameter (InletDiameter = 10 in). I want to use this parameter in multiple inventor models instead of recreating it every time in each model and the value 10in may change at some circumstances, at that time I don't want to open each model and change the parameter value, instead changing the value in the database has to reflect on all the models.
