Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create simplified part from an assembly for particular occurrences
2 REPLIES 2
ndillner343SKL
131 Views, 2 Replies
I'm looking to create a simplified part from an assembly and only include certain components of the assembly. Line 10 seems to be the issue in the code below. Any help with this would be greatly appreciated!
Dim wsPath As String = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
Dim simplifiedPath As String = wsPath & "\Pattern.ipt"
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oDef.Occurrences
Dim dirDef As DerivedPartDefinition = oDef.ReferenceComponents.DerivedPartComponents.CreateDefinition
For Each oOcc As ComponentOccurrence In oOccs
	If oOcc.Name.Contains("Vert") Or oOcc.Name.Contains("Horz") Then dirDef.AddOccurrence(oOcc)
Next
Dim simplifiedPart As DerivedPartComponent = oDef.ReferenceComponents.DerivedPartComponents.Add(dirDef)
Dim simplifiedDoc As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , True)
simplifiedDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(dirDef)
2 REPLIES 2
A.Acheson
in reply to: ndillner343SKL
Hi @ndillner343SKL
If you look at the derivedpartcomponents here you will see there is no method for create definition. Use one of the other available methods. The sample will give some more pointers as to how to set this up.
Regards
Alan
Hi, you can try this code,
 Traverse to the assembly find all occurrences and add them to a list off Occurrences
  Turn off visibility off the occurrences that not include Vert, Horz
  Create the derived part and save the part
  Turn on visibility off all occurrences off the assy.
  Sub main
        Dim oAssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
        Dim oFileName As String = oAssyDoc.FullDocumentName
		'Traverse to the assembly find all occurrences add them to a list off Occurrences
        Dim oOccs As List(Of ComponentOccurrence) = TraverseAssembly(oAssyDoc.ComponentDefinition.Occurrences, 1)
		' Turn off visibility off the occurrences
        SetVisibility(oOccs, False)
        oAssyDoc.Save2()
		' Create the derived part and save the par
        CreateDerivePart(oFileName)
		' Turn on visibility off all occurrences
        SetVisibility(oOccs, True)
    End Sub
    Private Function TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer) As List(Of ComponentOccurrence)
        Dim result As New List(Of ComponentOccurrence)
        Dim oOcclist As New List(Of ComponentOccurrence)
        Try
            ' Iterate through all of the occurrence in this collection.  This
            ' represents the occurrences at the top level of an assembly.
            Dim oOcc As ComponentOccurrence
            For Each oOcc In Occurrences
                oOcclist.Add(oOcc)
                If oOcc._DisplayName.Contains("Horz") Then
                    oOcclist.Remove(oOcc)
                If oOcc._DisplayName.Contains("Vert") Then
                ' Check to see if this occurrence represents a subassembly
                ' and recursively call this function to traverse through it.
                If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                    Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
                result = oOcclist
            Next
        Catch ex As Exception
        End Try
        Return result
    End Function
    Private Sub SetVisibility(ByVal oOccs As List(Of ComponentOccurrence), VisSet As Boolean)
        Try
            For Each oOcc In oOccs
                oOcc.Visible = VisSet
            Next
        End Try
    End Sub
    Private Sub CreateDerivePart(ByVal FullFileName As String)
        Dim oPartDocTemplate As String
        oPartDocTemplate = ThisApplication.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject, SystemOfMeasureEnum.kDefaultSystemOfMeasure, DraftingStandardEnum.kDefault_DraftingStandard)
        Dim oPartDoc As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oPartDocTemplate, True)
        ' Create a derived definition for the molded assembly.
        Dim oDerivedAsmDef As DerivedAssemblyDefinition
        oDerivedAsmDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(FullFileName)
        ' Create the derived assembly.
        oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAsmDef)
        Dim oFileNameCount As Integer = Strings.Len(FullFileName)
        Dim oFileNameNew As String = Strings.Left(FullFileName, (oFileNameCount - 4))
        oPartDoc.SaveAs(oFileNameNew & ".ipt", False)
        oPartDoc.Close()
    End Sub
Technology Administrators
